Cosmetic Threads in SOLIDWORKS describe the attributes of a specific hole so you don’t need to add real/feature threads to a model. A cosmetic thread represents the minor (inner) diameter of a thread on a boss or the major (outer) diameter of a thread on a hole and can include a hole callout in drawings.
Shaded Assembly View
Related Article >> Missing Cosmetic Threads and How to Fix Them in SOLIDWORKS
To begin, check the document properties to be sure you can view them as expected.
Note: Use CTRL + B (or Q) after all changes to be sure the threads display as intended.
There are four options to determine if you will see the threads display in an assembly.
I hope you found this article helpful. You can take a deeper dive into Cosmetic Thread editing and styles here.
How to Copy SOLIDWORKS Custom Properties to Other Files
Customizing the SOLIDWORKS Hole Callout File
About Randle Wood
