SOLIDWORKS Simulation has many great features to help you find data about your assemblies. One of which is the motion study. The motion study allows you to create simple animations of how your assembly moves. A more realistic simulation using motors, springs, and gravity can be defined using the basic motion option. Mass properties can be found at the end of your study, but what if we want to know the results of these physical interactions at different points within the motion analysis. How do we find these properties? That is the question we will answer in this article.
Our task is to find the mass properties of an assembly at any point within our motion analysis. We are going to walk through the process to find this information.
Here we have an assembly that we want to run a motion study on and find the mass properties at certain times.
I hope you found this SOLIDWORKS Simulation tutorial helpful. Learn more about Motion Studies and other Simulation studies below.
Free SOLIDWORKS Simulation Tutorials
SOLIDWORKS Motion Utilizing Design Studies to Evaluate What-if Scenarios
SOLIDWORKS Motion: A Tip for Handling Performance Hogs
About Nathen Blas
