SOLIDWORKS Path Mate Explained
Article by Rodolfo Gutierrez on Sep 08, 2021
In SOLIDWORKS, the Path Mate is useful when trying to constrain a selected point on an assembly component to a path. It offers control over the pitch, yaw, and roll of the component as it treks through the path.
In SOLIDWORKS, Path Mate is located in the Mate (Assembly toolbar) > Advanced tab > Path Mate. (Figure 1)
SOLIDWORKS Path Mate Location
Figure 1: Path Mate location
When using Path Mate, the first mate selection is for the component vertex; this is the point in the component that will pierce and travel along the path. (Figure 2)
Component Vertex Selection SOLIDWORKS Path Mate
Figure 2: Select component vertex
The second mate selection is the Path Selection. Here you will choose a curve, edge, or sketch entity. If you have more than one entity to select, click on the SelectionManager. (Figure 3)
SOLIDWORKS Path Selection
Figure 3: Path Selection
To optimize the movement of the component along the path, we are given Path Constraint, Pitch/Yaw Control, and Roll Control.
Path Constraint allows you to constrain the vertex with a specified distance from the end of the path or as a percentage along the path. (Figure 4)
SOLIDWORKS Path Constraint
Pitch/Yaw Control constrains one axis of the component to be tangent to the path. (Figure 5)
SOLIDWORKS Path Mate Pitch/Yaw Controls
Figure 5: Pitch/Yaw Controls
Roll Control constrains one axis of the component to align with a vector you select. You must select a linear edge or planar face for Up Vector. (Figure 6)
SOLIDWORKS Roll Controls
Figure 6: Roll Controls
Tip: You cannot use the same axis for both Pitch/Yaw Control and Roll Control.
More SOLIDWORKS Tips & Tricks
How to Mirror Parts in SOLIDWORKS Two Different Ways
SOLIDWORKS Wrap Feature Tutorial
Global Variables in SOLIDWORKS Explained
Easy Way to Link Properties to a SOLIDWORKS Drawing
VIEW ALL SOLIDWORKS TIPS & TRICKS
About Rodolfo Gutierrez
