How to Mirror Parts in SOLIDWORKS Two Different Ways
Article by Krystal Petersen on Aug 30, 2021
In this guide, we'll show how to mirror parts in SOLIDWORKS using two different methods. The first method stores a mirrored version of the same part. The second method creates a derived part, using the mirror part command.
Method #1: Mirrored Version, Same Part
With the SOLIDWORKS part you want to mirror open, create a configuration and give it a name. In this instance, we will call it LH (Left Hand).
How to Mirror Parts in SOLIDWORKS: Mirrored Version, Same Part
Within that configuration, select the Mirror option from the CommandManager.
SOLIDWORKS Mirror Options CommandManager
Select a face that will serve as the plane of symmetry for the mirror.
Mirror Plane Symmetry in SOLIDWORKS
There are a few different options depending on what you are mirroring:
  • Features to Mirror
  • Faces to Mirror
  • Bodies to Mirror
Options for Mirroring Parts in SOLIDWORKS
Each option will mirror the selection you choose. For this instance, we will use the Bodies to Mirror option.
Note: Be sure to uncheck Merge Solids if you do not want the two bodies to be merged together.
Mirrored Body in SOLIDWORKS
Once the newly created mirror body is created, you can then delete the initial part with a delete bodies command. (Insert > Features > Delete/Keep Body).
With the body now deleted, the process is complete and you can toggle between the right-hand and the left-hand configurations within the part.
SOLIDWORKS Tutorial: Mirroring Parts
Method #2: Mirrored Part, Derived Version
Have the SOLIDWORKS part you wish to mirror open and, prior to selecting the mirror command, have a plane selected to be the plane of symmetry. This step must be done for the command to even become available.
How to Mirror Parts in SOLIDWORKS: Mirrored Part, Derived Version
With the face you plan to use as the plane of symmetry selected, go to Insert > Mirrored Part. Once the command is active, you will see the Insert Part PropertyManager window with selections for what will come across as well as the option to establish a reference between the new part and the source part.
Insert Part Solid Bodies Option in SOLIDWORKS
If you keep the link intact, you will see changes flow from the source part to the mirrored part. If you do not want that, be sure to break the link between the two files. With the selections you want selected, click Okay and you have now created a derived part from a mirror.
SOLIDWORKS Derived Part from Mirror
Please also note, that when selecting Break Link, it brings over the part without any available options to choose from (as shown in the video below).
GoEngineer Video Mirroring Parts in SOLIDWORKS
Now you know how to mirror parts in SOLIDWORKS. Check out more tutorials below!
SOLIDWORKS CAD Cheat Sheet
More SOLIDWORKS Tutorials
SOLIDWORKS Wrap Feature Tutorial
Global Variables in SOLIDWORKS Explained
Easy Way to Link Properties to a SOLIDWORKS Drawing
Creating a Non-circular Helix in SOLIDWORKS with Surfacing Commands
VIEW ALL SOLIDWORKS TUTORIALS
About Krystal Petersen
View all posts by Krystal Petersen
