SOLIDWORKS Intersection Curve Tool Explained
Article by GoEngineer on Aug 20, 2018
Why do we need the Intersection Curve Tool?
In this example, we've received a part from a different system and we imported it into SOLIDWORKS without any feature history. The part has five fingers, and we need the exact geometry sketch of a finger so we can use it again in another part file. The SOLIDWORKS Intersection Curve tool is the best tool for the job. Everywhere a selected plane intersects a select face/surface, Intersection Curve will make the sketch line for us.
Select a plane that intersects the geometry in an appropriate manner
Isometric View in a SOLIDWORKS Geometry
Here, the front plane is selected from an isometric view, which appears to intersect one of the latch fingers.
Model is turned to verify that the plane intersects the latch finger geometry
Plane Intersection in SOLIDWORKS
Select the Plane then the Interesction Curve Tool
SOLIDWORKS Intersection Curve Tool Selection
Intersection curve lives in Tools > Sketch Tools > Intersection Curve.
Intersection Curve Tool dialog box and selections
SOLIDWORKS Intersection Curve Tool Dialog Box
Once the tool has started, select the plane if not already selected, then all the faces the plane intersects that you want sketch lines through.
The other side of the Latch finger selections
SOLIDWORKS Latch Finger Selection
Finish selecting all the faces for the plane to intersect to make sketch entities.
Your sketch entities show up as soon as you click the green check
Sketch Entities in SOLIDWORKS
If you have missed any places, the dialog box is still up. Select them and click the green checkmark for OK. You can also restart the feature if it got dismissed too early.
This shows the sketch with the solid body hidden
Hidden Solid Body in SOLIDWORKS
Exit the sketch when all entities are there.
Now would be a good time to copy the sketch to paste onto a plane in a new part
Intersection Curve Tool SOLIDWORKS Tutorial
Edit copy or Control C. Go to a new part and pick a plane or face to paste the new sketch made by the SOLIDWORKS Intersection Curve tool. Copy and paste within the same part file also, of course. Edit and alter as needed.
Learn More About SOLIDWORKS
SOLIDWORKS Wrap Feature Tutorial
Global Variables in SOLIDWORKS Explained
SOLIDWORKS Content: Download Additional Routing Libraries
Easy Way to Link Properties to a SOLIDWORKS Drawing
VIEW ALL SOLIDWORKS TUTORIALS
