Introduction to DimXpert in SOLIDWORKS
Article by Gary Ballentine on Sep 15, 2022
This article explains how to use DimXpert in SOLIDWORKS to insert dimensions and tolerances in 3D space so you can effectively share your design with others.
What is DimXpert?
DimXpert is a tool built into SOLIDWORKS that lets users quickly and easily dimension models in 3D space. DimXpert allows us to easily communicate sizes, locations, and tolerances so that other users can easily understand and manufacture our parts.
We can manually dimension selected features or automatically dimension an entire model using Auto Dimension Scheme (aka the 'easy' button). Third parties can then view the dimensions in SOLIDWORKS or export them in a specific format (e.g., a PDF).
How to Use DimXpert
The DimXpert tab is located in the column between the ConfigurationManager and DisplayManager on the left side of the screen. This is the default location, but its tools can also be accessed through the MBD Dimensions tab should you choose to enable it.
DimXpert Manager and MBD Dimensions Location in SOLIDWORKS
Basic DimXpert tool commands are available as icons in the DimXpert Manager. If you hover over them, a description will appear on the screen.
Basic DimXpert Commands
DimXpert Commands
The Size Dimension tool lets us insert dimensions and tolerances for specific features such as holes. We can place the dimension anywhere in the graphics area.
DimXpert SOLIDWORKS Location Dimension Tool
Location Dimension lets us specify the location of a feature relative to a datum, such as a plane. This can give us lengths of features in a format that helps in manufacturing.
SOLIDWORKS DimXpert Show Tolerance
The Show Tolerance Status tool shows whether or not a feature is fully dimensioned. Green means that the feature is fully dimensioned.
DimXpert SOLIDWORKS Show Tolerance Status
The Auto Dimension Scheme tool lets us automatically dimension the entire model with reference to specific datums.
DimXpert SOLIDWORKS Auto Dimension Scheme
To use the Auto Dimension Scheme tool, we must specify datums for SOLIDWORKS to use as reference points to dimension from. We can also specify which features to include or exclude.
Using SOLIDWORKS DimXpert Auto Dimension Scheme
Click the green check and the dimensions populate. You can click and drag the dimensions to increase their visibility as needed.
SOLIDWORKS DimXpert Dimensioned Part
When the part is dimensioned, you can share the model or export it for non-SOLIDWORKS users. A simple File > Save As will let you save the current view as a 2D pdf. If you have a SOLIDWORKS MBD license, you can export as a 3D pdf as well.
SOLIDWORKS DimXpert Export File Options
I hope you found this tutorial helpful. Learn more about SOLIDWORKS by checking out more tips and tricks below.
More SOLIDWORKS Tutorials
SOLIDWORKS MBD - Understanding DimXpert Colors
Weld Bead vs Fillet Bead: SOLIDWORKS Feature Comparison
SOLIDWORKS Design Checker Tool Explained
Why is My Assembly Invisible in SOLIDWORKS?
SOLIDWORKS MBD Custom 3D PDF Template Tutorial
VIEW ALL SOLIDWORKS TUTORIALS
About Gary Ballentine
