The Abaqus Associative Interface is tailored to integrate with SOLIDWORKS users. It provides a direct channel to transfer geometry from SOLIDWORKS to Abaqus/CAE. With this interface, users can easily send individual components or a full assembly from SOLIDWORKS to Abaqus/CAE using a single click. Moreover, if you update your model in SOLIDWORKS, you can swiftly import those changes to Abaqus/CAE without losing any pre-defined analysis settings. This integration is made possible by a plugin for SOLIDWORKS and is managed via the CAD Connection tools in Abaqus/CAE.
The plugin typically comes packaged with the Abaqus installation files, which can be downloaded from https://software.3ds.com. Please refer to How to Install Abaqus for more information.
You can obtain the plugin in two different ways:
Prerequisites
Installation Steps
Enabling the SOLIDWORKS Associative Interface Add-in
Following the activation, if you enabled the Active Add-ins option for the SOLIDWORKS Associative Interface add-in, you'll notice that Abaqus is now available in the SOLIDWORKS main Tools menu.
Additionally, the Export to Abaqus/CAE icon will be present in the SOLIDWORKS toolbar.
Below is the plugin in action.
For more details on this, see the SOLIDWORKS ASSOCIATIVE INTERFACE USER’S GUIDE pdf packaged with the Abaqus installation files. Also see the SOLIDWORKS Compatibility Matrix.
Abaqus FEA: Powerful Finite Element Modeling
Abaqus Solvers: Empowering Engineers in Every FEA Scenario
SOLIDWORKS Simulation vs Abaqus: When Should You Upgrade?
The Ultimate Guide to Abaqus Computing
Getting Started: Abaqus User Subroutine Compilation in Windows Using Intel OneAPI
About Bilal Abdul Halim
Bilal Abdul Halim is an Application Engineer at GoEngineer specializing in Abaqus. Bilal holds a Bachelor’s degree in Mechanical Engineering and a Master's degree in Experimental Fluid Mechanics where he studied the effects of corona discharge on viscous oil using particle image velocimetry. When not at work, Bilal is usually playing ping pong or trying different restaurants.
