How to Import SOLIDWORKS Parts Into 3DEXPEREINCE
Article by Andrew Smith on Sep 21, 2022
So, you want to use 3DEXPERIENCE with parts modeled in SOLIDWORKS?
The 3DEXPERIENCE platform is a robust, cloud-based tool for companies looking for new ways to innovate in a collaborative environment. The breadth of available tools, apps, and roles is incredible, but for this series, we will focus on the CFD (Computational Fluid Dynamics) simulation role (FMK) and its accompanying apps. This post covers how to import parts from SOLIDWORKS into 3DEXPERIENCE. Moving forward, we will assume the design is complete and ready to be imported to 3DEXPERIENCE for Simulation (i.e., no further work in SOLIDWORKS is needed).
Importing parts into 3DEXPERIENCE directly from SOLIDWORKS will allow you to keep the SOLIDWORKS and 3DEXPERIENCE parts linked; allowing you to update changes in SOLIDWORKS to your part and have those changes reflected in 3DEXPERIENCE.
1. Open SOLIDWORKS Properly
To open SOLIDWORKS properly, you may need to close it first. To ensure that the parts or assemblies you have made can be imported into 3DEXPERIENCE, you should open SOLIDWORKS via 3DEXPERIENCE using the SOLIDWORKS Add-in or SOLIDWORKS Connected apps.
If you opened your desktop SOLIDWORKS from the start menu without going through 3DEXPERIENCE, you must close and re-open the application from the apps.
Typical steps could be like this:
  1. Close SOLIDWORKS (if not opened from 3DEXPERIENCE)
  2. Go to 3DEXPERIENCE in your web browser
  3. Select the appropriate app (SOLIDWORKS Add-in or SOLIDWORKS connected).
SOLIDWORKS Add-in Icon and SOLIDWORKS Connected Icon
2. Open Your Design in SOLIDWORKS
Open your design as you have done before in SOLIDWORKS. Notice the 3DEXPERIENCE button on the right-hand side and continue to the next step.
3. Open the 3DEXPERIENCE Task Pane
Now that you have opened SOLIDWORKS from 3DEXPERIENCE, you will be able to save your designs to the cloud. In SOLIDWORKS, click on the 3DEXPERIENCE Task Pane Tab, shown below.
3DEXPERIENCE Task Pane Located in SOLIDWORKS
The 3DEXPERIENCE Task Pane Tab shows you some details of the part you currently have open. Most important for our purposes is the Status column. This shows the Save Status of the design in 3DEXPERIENCE.
Note that the part may be saved locally, but this will not save it to the cloud. The orange floppy disk symbol in the figure below shows that this part has not been saved to the 3DEXPERIENCE platform.
3DEXPERIENCE Save Status
4. Saving the Design to the Cloud
Right-clicking the design in the 3DEXPERIENCE Task Pane Tab will present several options. The options we care about here are: Save, Save with Options, and Lock/Unlock
Save a SOLIDWORKS Part in the 3DEXPERIENCE Cloud
  • Locking the design prevents other users from editing it.
  • Save will save the part to the cloud using the default options.
  • Save with Options allows you to specify several aspects of the save.
From the Save with Options window, you can save the part to a specific bookmark, create a new revision, check the maturity state, and more. You may need to lock the design before you can save it. Once everything is as you like it, simply click Save.
Save to 3DEXPEREINCE a SOLIDWORKS Part File
5. Wait for Conversion
After saving, the Status will show a green check, and the conversion status will turn yellow, indicating that the file is saved but not yet ready to be opened in any 3DEXPERIENCE apps.
3DEXPERIENCE Conversion Status Saved But Not Yet Ready
A brief time later, the conversion status will change to green, showing that the part is ready to be opened in 3DEXPERIENCE.
Conversion Status SOLIDWORKS Part Ready for 3DEXPERIENCE
6. Open Your solidworks part in 3DEXPERIENCE
At this point, the SOLIDWORKS part is ready to be opened in 3DEXPERIENCE. To do so, select the part so that it is highlighted in blue then click on the compass at the top left section of the pane.
Open a SOLIDWORKS Design in 3DEXPERIENCE
This opens the 3DEXPERIENCE roles and apps from which we will choose the Fluid Scenario Creation app. Although, we could use any of the Scenario Creation apps.
3DEXPERIENCE Apps
After a few moments, the app will open with our part loaded.
Import SOLIDWORKS Part into 3DEXPERIENCE Platform Tutorial
Here is where the fun begins.
A Note on Importing Part and Assembly Files
It should be noted that you can also import the files into 3DEXPERIENCE directly. This is an acceptable way of doing it, but the links to the part will be severed. In other words, the part imported to 3DEXPERIENCE will not update if the part is updated in SOLIDWORKS.
Importing your designs from SOLIDWORKS to 3DEXPERIENCE is a small and easy step that allows you to access the power of 3DEXPERIENCE. It is the first step on our way to running CFD simulation on these designs through the Fluid Dynamics Engineer (FMK) role.
More 3DEXPERIENCE Tutorials
3DEXPERIENCE Platform 2022X FD03 Release: Top Enhancements
What’s New SOLIDWORKS 2022: 3DEXPERIENCE
3DEXPERIENCE Platform Beam Analysis
3DEXPERIENCE SIMULIA: Better Industrial Equipment Design
VIEW ALL 3DEXPERIENCE TUTORIALS
About Andrew Smith
View all posts by Andrew Smith
