Edit Flattened Harness Routes: SOLIDWORKS Electrical 3D
Article by GoEngineer on Dec 01, 2015
This tutorial explains how to edit flattened harness routes in SOLIDWORKS Electrical 3D. Flattened representations of a SOLIDWORKS harness can be difficult to read in its default state. With the 'Edit Flattened Route' command, a high-quality representation of the flattened route can be created with ease.
Once the harness is routed in 3D, there is a new routing sub-assembly in the FeatureManager Design Tree.
Edit Flattened Harness Routes in SOLIDWORKS Electrical 3D
Right-click the routing sub-assembly and select 'Flatten Route.'
Flatten Route Option in SOLIDWORKS Electrical 3D
Select the type of flatten route (defined below) and select the different drawing options that are required in the Flattened Drawing. Select OK (green check mark).
  • Annotation allows the creation of a flattened configuration that is displayed using the standard drawing sheet with views.
  • Manufacture allows the creation of a flattened configuration that is displayed true size on a formboard.
Annotation and Manufacture Flatten Route Options in SOLIDWORKS Electrical 3D
A flattened harness assembly and a flattened harness drawing are created and opened. The flattened harness drawing will be the file that is displayed. If the harness assembly is too complex the flattened representation can be cluttered.
Flatten Harness Assembly in SOLIDWORKS Electrical 3D
Open up the flattened harness assembly. Go to Window and select the file. Alternatively, use CTRL+Tab to get to the right document.
Flattened Harness Assembly Example in SOLIDWORKS Electrical 3D
Right-click the AnnotateFlattenedRoute# and select 'Edit Flattened Route.'
Edit Flattened Route Option in SOLIDWORKS Electrical 3D
Five tools aid in editing the flattened route
  1. Drag - Enables the user to drag any sketch point or line in the flattened sketch to the desired position. The 'Flip Selection' check box can be used to select the complementary segments.
  2. Horizontal – Constrains the selected segment horizontally.
  3. Vertical – Constrains the selected segment vertically.
  4. Delete Relations – Delete relationships that segments can be dragged to any position.
  5. Fanout – Enables the manipulation of the fanout segments. The 'Position Angle' defines the position of the fanout with respect to the base segment. The 'Spacing Angle' defines the spacing between fanout segments.
Edit Flattened Route Options in SOLIDWORKS Electrical 3D
Once the manipulation is completed, hit OK (green check mark). Navigate back to the flattened harness drawing and the changes to the flattened harness assembly will automatically propagate to the drawing.
More SOLIDWORKS Electrical Tutorials
An Easy Way to Add Watermarks in SOLIDWORKS Electrical
Why Won't My Wires Route in SOLIDWORKS Electrical (Part 1 and Part 2)
SOLIDWORKS Electrical 2020 Leader Lines - What's New
Wrapping Attribute Text in SOLIDWORKS Electrical
SOLIDWORKS Electrical Videos
GoEngineer Video Taking the Next Step with Your Schematics Taking the Next Step with your Schematics
GoEngineer Video Multiwires Expanding and Compressing Tutorial Multiwires Expanding and Compressing Tutorial
GoEngineer Video Creating Solutions - Resolving Collarboration Issues Creating Solutions - Resolving Collaboration Issues
