DriveWorksXpress Activation Quick Tip
Article by GoEngineer on Dec 21, 2015
Inside every seat of SOLIDWORKS, a copy of DriveWorksXpress is included at no additional cost. However, the activation needs to happen before the software can be used.
Note: View our DriveWorks page to compare DriveWorks packages.
If you look under the “Evaluate” tab in SOLIDWORKS you will see the icon for DriveWorksXpress Wizard:
DriveWorksXpress Activation Evaluate Tab
Or:
Activate DriveWorksXpress
Launch the add-in.
The first time you use the add-in, you will need to activate it for use. This is a very simple process. The launching of the software will activate a window asking you to enter the DriveWorksXpress Product Code:
Enable DriveWorksXpress
Click on the My.solidworks.com/xpress link provided and it will take you to a website that will give you the free activation code once you log in.
DriveWorksXpress Activation Code
Copy and paste the activation code back into the earlier DriveWorksXpress Product Code box and hit OK, and you’re done.
DriveWorksXpress should now be available to use.
I hope you found this quick tip helpful. Learn more about SOLIDWORKS below.
Easy Way to Change Languages in SOLIDWORKS
BOM Compare - SOLIDWORKS Utilities
SOLIDWORKS Toolbox Default Search Location Option
Link Sketch Text to File Properties in SOLIDWORKS
Quick Clicks in SOLIDWORKS
