Easy Way to Change the Language in SOLIDWORKS
Article by Tashayla Openshaw on Dec 19, 2020
Did you know that you can change the language in SOLIDWORKS without needing to change the language of your system? It's possible and relatively simple.
Changing the Language in an Existing SOLIDWORKS Installation
The easiest way to change the language in an existing SOLIDWORKS installation is by tricking SOLIDWORKS into thinking the new language is English. There must be a full installation file set for the wanted language. Follow the instructions below to modify your SOLIDWORKS installation to install the full-file set for the desired language.
  1. Open the Control Panel
    1. Windows Start Button > type 'Control Panel'
  2. Select 'Programs' or 'Programs and Features', and choose 'Uninstall a Program'
  3. Find the version of SOLIDWORKS to modify, right-click on it and select 'Change'
  4. As long as you have recently rebooted your computer, you can select 'Ok' on the pop-up that says “A Windows reboot is pending from a previous installation…” (this is a known bug in the Installation Manager)
    SOLIDWORKS Installation Manager to Change Language
  5. Choose 'Modify your installation' and select 'Next' until you get to the Product Selection page of the installation
  6. Expand 'SOLIDWORKS Languages' (by selecting the arrow next to it) and check the box next to the language you would like
    Modify Installation to Change Language in SOLIDWORKS
    Change Language to German in SOLIDWORKS
  7. Select 'Next' then 'Modify' on the last page.
  8. Once it successfully installed, open File Explorer and navigate to:
    How to Change the Language in SOLIDWORKS 2021
  9. Rename the English folder to “english.old” and the wanted language folder to “English”.
    How to Change a Language in SOLIDWORKS 2021
  10. Launch SOLIDWORKS and it will run in the wanted language.
    Change Language New SOLIDWORKS Installation
Installing Language in Brand New SOLIDWORKS Installation
To install SOLIDWORKS with the specific language right off the bat, select the desired language(s) in the “Product Selection” page of the installation, then follow steps 6 - 10 as discussed above.
I hope you found this article helpful. Learn more about SOLIDWORKS in the tips and tricks below.
SOLIDWORKS CAD Cheat Sheet
More SOLIDWORKS Tips & Tricks
BOM Compare - SOLIDWORKS Utilities
SOLIDWORKS Toolbox Default Search Location Option
Link Sketch Text to File Properties in SOLIDWORKS
Quick Clicks in SOLIDWORKS
Using the move/Copy Body Feature in SOLIDWORKS
How to Install and Troubleshoot Fonts in SOLIDWORKS
About Tashayla Openshaw
