DraftSight 101 - Basic 3D Shapes
Article by Dennis Barnes on Mar 24, 2025
To create 3D objects in DraftSight, DraftSight Premium (either stand-alone Premium or Enterprise Plus) is required. This article is an introduction to basic 3D shapes (box, pyramid, wedge, cone, cylinder, sphere, and torus) and explains how to access the tools to create them.
Below is the DraftSight Features Matrix with the Premium tools highlighted.
DraftSight 2025 Product Matrix Essential Tools
DraftSight 2025 Product Matrix Productivity Tools
DraftSight 2025 Product Matrix Mechanical and Interoperability Tools
DraftSight 2025 Product Matrix Cloud Collaboration Tools
Below is the standard DraftSight interface. Notice in the upper right corner that the Drafting and Annotations workspace is active, and the ribbon tools and tabs are available.
DraftSight Drafting and Annotations Command Window Option
Change the workspace to 3D Modeling to access the tools you need.
DraftSight 3D Modeling Option in the Command Window
Select the View tab > Views > SE-Isometric and change the view to Isometric to see all three axes.
Create a Box
In the Home tab, select Box. The first input will be the first corner. Enter 0,0,0 in the command window. Either move your cursor to 10,10 or enter 10,10. Lastly, click in the positive Z-axis to set the height or enter 10. Your shape should look like this:
DraftSight 101: Basic 3D Shapes
To view the box as a solid, open the View tab, select the Shadeview button dropdown, and select Flat with Edges.
DraftSight Flat with Edges Option
The result will look like this:
How to Create a 3D Box in DraftSight
Select the solid and hit the Delete key.
Create a Pyramid
At the Home tab, select the Box dropdown and the Pyramid tool. The first input will be the center of the base. Enter 0,0,0 in the command window. Either move your cursor to 10,0 or enter 10. Lastly, click in the positive Z-axis to set the height or enter 20. Since the shaded view was already on your shape should look like this:
How to Create a Pyramid in DraftSight
Create a Wedge
Go to the Home tab, select the Box dropdown and the Wedge tool. The first input will be the corner of the base. Enter 0,0,0 in the command window. Either move your cursor to 10,10 or enter 10,10. Lastly, click in the positive Z-axis to set the height or enter 20. Since the shaded view was already on your shape should look like this:
How to Create a Wedge Shape in DraftSight
Create a Cone
Go to the Home tab and select the Cone button. The first input will be the corner of the base. Enter 0,0,0 in the command window. Next will be the radius. Either move your cursor to 10,0 or enter 10. Lastly, click in the positive Z-axis to set the height or enter 20. Since the shaded view was already on, your shape should look like this:
How to Create a Cone in DraftSight
Create a Cylinder
Go to the Home tab, select the Cone dropdown, and then the Cylinder button. The first input will be the center point of the base. Enter 0,0,0 in the command window. Next will be the radius. Either move your cursor to 10,0 or enter 10. Lastly, click in the positive Z-axis to set the height or enter 20. Since the shaded view was already on, your shape should look like this:
How to Create a Cylinder Shape in DraftSight
Create a Sphere
Go to the Home tab, select the Cone dropdown, and then the Sphere button. The first input will be the center point of the sphere. Enter 0,0,0 in the Command Window. Next will be the radius. Either move your cursor to 10,0 or enter 10. Since the shaded view was already on, your shape should look like this:
How to Create a Sphere in DraftSight
Create a Torus
Go to the Home tab, select the Cone dropdown, and then the Torus button. The first input will be the center point of the sphere. Enter 0,0,0 in the command window. Next will be the radius. Either move your cursor to 20,0 or enter 20. The last input is for the radius of the tube. Move your cursor to 25,0,0 or enter 5. Since the shaded view was already on, your shape should look like this:
How to Create a Torus in DraftSight
That covers the basic SOLIDWORKS shapes in DraftSight Premium and Enterprise Plus. Check out more tips and tricks below. Additionally, join the GoEngineer Community to create forum posts, enter design contests, and answer questions from other DraftSight users.
DraftSight Training
Want to take your DraftSight skills to the next level? Enroll in our DraftSight Essentials online training course. For new users and former AutoCAD users, this course is designed to use the DraftSight software through the user interface. Learn how to make coordinates, create drawings, modify entities, properties, and more.
Enroll in the Official DraftSight Essentials Training Course at GoEngineer
Editor's Note: This article was originally published in February 2022 and has been updated for accuracy and comprehensiveness.
Using Sketched Contours to Create 3D Extrusions in DraftSight
How to Create Simple 3D Models with DraftSight
DraftSight Make Flat Snapshot Workaround
Master Layers in DraftSight with Layer States Manager
How to Use AutoStack in DraftSight
VIEW ALL DRAFTSIGHT ARTICLES
About Dennis Barnes
View all posts by Dennis Barnes
