Creating a Coordinate System in CAMWorks
Article by GoEngineer on May 06, 2017
Creating a Coordinate System in CAMWorks can help orient your part and is necessary when programming a 4th or 5th axis part and assemblies.
Below is the part that will be used in this demonstration.
CAMWorks Creating Coordinate Systems
An origin can be created without using a sketch to define it, however, using a sketch is a preferred method especially when the part doesn’t have 90-degree angles. In this example, I have created a sketch that has two construction lines 90 degrees from each other which will be my X and Y axis.
Creating Coordinate Systems in CAMWorks
Now the Coordinate System feature needs to be selected. It’s found in the Reference Geometry drop-down.
CAMWorks Coordinate System Reference Geometry
Then the X, Y, and Z axis need to be defined as well as a point. To do this, we will select the point where the construction lines meet, then select one of the construction lines to be our “X” axis and the other the “Y” axis with the “Z” axis then becoming able to toggle up or down.
Define Axes in CAMWorks for Coordinate Systems
When finished you will have a Coordinate System in the FeatureManager Tree and it will be displayed on the part.
CAMWorks FeatureManager Design Tree Coordinate System
Once in CAMWorks, right-click on CAMWorks NC Manager and select Define Machine.
CAMWorks NC Manager Define Machine
Then select the Setup tab and you will need to select the Coordinate System so that it populates in the Selected entity box.
CAMWorks Machine Setup Coordinate Systems
You will then need to Edit Definition for the Mill Part Setup in the CAMWorks Operation tab. In the Origin tab, select Fixture coordinate system so that the origin will update to the coordinate system.
CAMWorks Part Setup Parameters Origin Tab
The origin is now set precisely on the coordinate system that was created.
Learn More About SOLIDWORKS CAM and CAMWorks
Creating a Threadmill Feature in CAMWorks
CAMWorks Milling Features and Allowable Operations
Importing the Technology Database in CAMWorks
CAMWorks License Manager
CAMWorks Best Practices for Updating Your Installation
