Check Tool SOLIDWORKS Tutorial
Article by David Cersley on Jul 21, 2022
It doesn't matter if you're new to SOLIDWORKS or a power user - errors can happen. In this quick tip, learn about a handy tool to have in your toolbox that can save the day when validating and checking your parts for geometry errors.
SOLIDWORKS Check Tool Icon
Evaluate > Check
The Check tool has saved me a couple of times, especially when evaluating model issues. To use the Check tool, go to Location Tools > Evaluate > Check...
Alternatively, the Check Feature will appear if you do a command search and type "Check".
Check Entity
Upon activation, there are several defaults to check Solids and Surfaces. In order to evaluate a body or surface, left mouse click on the body in question and then hit the Check
Once you hit Check, SOLIDWORKS, based on the defaults selected, allows you to check for invalid faces, edges, minimum radius of curvature, edge gaps, and vertex gaps.
Results List SOLIDWORKS Check Entity Tool
Result List
In the Result list, we can see if there are faces in question. In this example, when we select the surface model, three Open surface issues are found.
If we left mouse click on the Open surface (#), we can see that SOLIDWORKS highlights the face in blue and an orange arrow appears to edges or surfaces in question.
SOLIDWORKS Check Entity Results
Now that we can see the open faces, we can revise the knit or maybe you created a new surface reknit, and with two solid bodies, the Combine tool is no longer greyed out.
I hope this tool helps you out the next time you need to evaluate your models.
More SOLIDWORKS Tutorials
SOLIDWORKS Zero-thickness Error: What Does It Mean?
SOLIDWORKS: Detecting & Resolving Interferences
Add Dimensions While Sketching in SOLIDWORKS
SOLIDWORKS Assembly Hole Series Explained
How to Use the Import Diagnostics Tool in SOLIDWORKS
VIEW ALL SOLIDWORKS TUTORIALS
About David Cersley
David has been using SOLIDWORKS since 2005 across multiple industries most notably Golf Club Design. He owned and operated a successful design and consulting company that used SOLIDWORKS to bring napkin sketches to production. The industries he's been a part of range from Medical, Aquaponics, Forging, CNC Shops, Roto-Molding factories. He is a proud father to daughter Emmaline (8) and is a husband of 19 years. He is a two-time Ironman finisher and recently qualified for the Boston Marathon.
View all posts by David Cersley
