It does not matter whether your SOLIDWORKS Flow Simulation analysis is complex or simple, if you make it a habit to follow the five quick and easy steps outlined in this document, you will possibly save yourself hours of headache downstream after you have already spent hours setting up your Flow Simulation Study.
You now choose to mesh/run your SOLIDWORKS Flow Simulation analysis, but the solver fails, and you now need to go back and investigate what is wrong with your model. All of these steps are equally important and all need to be performed, but not in any specific order.
If you go to Tools>Check you can pull up the Check Entity Command Manager where you can specify what type of invalid geometry you would like to check for in your part or assembly. Press the Check button to check your model's geometry. Any invalid geometry will be shown in the bottom box of this CommandManager. Now you know where to go to fix your model's invalid geometries.
To activate this tool go to Tools>Options>System Options Tab>Performance>Verification on Rebuild checkbox. Make sure that this check box is checked and press OK. Now press CTRL – Q which is a global rebuild hotkey. The CTRL – Q hotkey will make sure that the whole model is rebuilt.
The active Verification on Rebuild option will make SOLIDWORKS checks every feature against all other existing faces and edges. Not just the adjacent faces and edges to that feature.
This operation may take a while depending on your file size and complexity, but it is worth it because you may find some features that fail which you now can go back and fix before you run your SOLIDWORKS Flow Simulation and it fails for reasons that you do not understand.
This is a very useful tool that can be found in either the Evaluation tab on your CommandManager or under Tools>Interference Detection (at the assembly level).
This tool can be found by going to Tools>Flow Simulation>Tools<Check Geometry. Once this tool is open press the check button and under the results section, it will tell you whether the model has any invalid contacts, or is not air-tight.
The Import Diagnostics feature should be used on all imported part files (IGES, STEP, Parasolid, etc.). Sometimes when a part or assembly file is imported into SOLIDWORKS it can come in with faulty geometry such as faulty faces or gaps that will cause errors to appear in a Flow study if they are not healed before running the study.
The Import Diagnostics CommandManager can be told to ‘Attempt to Heal all Faces’ or ‘Attempt to Heal All Gaps’ or both simultaneously by clicking ‘Attempt to Heal All’. If there are any faces or gaps in the imported geometry that still cannot be healed by using this tool then you as the user will have to go in and manually fix whatever the problem areas are before running Flow Simulation on this imported part or assembly.
Customizing SOLIDWORKS Flow Simulation Feature Tree Categories
Different Pressures in SOLIDWORKS Flow Simulation
Backspin is Important to your Basketball Free Throw! A SOLIDWORKS Simulation Study
About Taran Packer
