SOLIDWORKS Default Mesh Size
Article by Shaun Bentley on Jul 19, 2021
ISOLIDWORKS Simulation, the default mesh size is the value that is initially assigned to the Global Size field of the Standard Mesh, but also influences the maximum and minimum used in Curvature Based meshes.
Determining Default Mesh Size in SOLIDWORKS Simulation
Figure 1 - Standard Mesh; tolerance can be smaller if you use small mesh controls.
What factors decide the default mesh size?
Mesh Factors
The software only uses the following three parameters to determine the default mesh size:
  • Volume*
  • Surface Area**
  • Minimum Radius of Curvature***
SOLIDWORKS will determine two factors based on volume and surface area. Equations for these factors are shown below:
SOLIDWORKS Simulation Mesh Factor Equation
Then, SOLIDWORKS Simulation picks whichever one of these factors is larger and assigns that as the default size. The denominators in these fractions are based on the developers targeting roughly 10,000 elements for a simple cube or square surface, but for more complicated models, this count may vary substantially from the target.
This accounts for the Volume and Surface Area factors, but where does the Minimum Radius of Curvature factor in?
The minimum radius of curvature value is used for defaults in both the Curvature Based and Blended Curvature Based mesh to decide on a maximum and minimum element size.
Minimum Radius Curvature in SOLIDWORKS Simulation
Figure 2 - Curvature Based Mesh; values are for 2020 and 2021.
Levels of Curvature
Level 1: your model has no curvature or large curvature present (>131% of the default mesh size).
  • The Maximum is set to 1x the default size
  • The Minimum is set to 1x the default size
    Level 1 Curvature with no curvature or large curvature present
Level 2: your model has a moderately small curvature present (between 44% and 131% of the default mesh size).
  • The Minimum is set to 1/3 of the default size
    Level 2 Curvature a model with moderately small curvature present
Level 3: your model has a small curvature present (<44% of default mesh size).
  • The Maximum is set to 2x the default size
  • The Minimum is set to 2/5 of the default size
    Level 3 Curvature is a model that has small curvature present
If you are curious and want to test out these defaults for yourself, you can use this spreadsheet to compare with SOLIDWORKS Simulation values.
Footnotes
*Volume can be evaluated from the Mass Properties tool
**Surface Area can be evaluated from the Mass Properties tool, but if your model includes shell elements, their areas will need to be doubled to account for both sides of the shell
***Minimum Radius of Curvature can be evaluated from the Check Entity tool
Learn More About SOLIDWORKS Simulation Mesh
How Do I Know My Mesh Is Good Enough?
Draft Quality & High Quality Mesh SOLIDWORKS 2020 – New!
SOLIDWORKS Simulation: Troubleshooting Why a Single Part Will Not Mesh
SOLIDWORKS Simulation Solution Adaptive Mesh Refinement
SOLIDWORKS Flow Simulation: Solution Adaptive Mesh Refinement
About Shaun Bentley
