After installing SOLIDWORKS on a new computer, there are a lot of unknown files and tools that come as part of the installation package that can be handy in certain situations. The SOLIDWORKS Simulation Cleaning utility is one of these. You can find this utility in the following file directory:
The Cleaning Utility permanently deletes simulation data connected to a SOLIDWORKS file while leaving the SOLIDWORKS file intact. The reasons you would want to do that are listed below.
To run this tool, make sure the file or files to be cleaned are no longer open, then double left-click the simulation cleaning utility.
The SOLIDWORKS Simulation Cleaning Utility CommandManager will open where you can choose what type of simulation data you want to clean. Then browse to the file you would like to clean and press Clean File.
After going through these operations, the selected file has been wiped of whatever simulation data was checked by the user and is now a clean slate.
Unfortunately, this tool leaves nothing behind so all the work put into the simulation up to this point will need to be redone, but in the situations mentioned above, this is a necessary evil.
SOLIDWORKS Motion Analysis Motor Torque & Power
SOLIDWORKS Simulation Natural Frequencies, Mode Shapes, and Vibration Explained
How to Set Up a Thermal Study in SOLIDWORKS Simulation Professional
About Taran Packer
