The mixing of fluids is a phenomenon that needs to be accurately modeled in order to understand the behavior of the different fluids involved, as well as understanding the rate that the mixing happens. SOLIDWORKS Flow Simulation allows the use of non-newtonian fluids, gases, real gases, and liquids. For fluid mixing, all of the fluids being mixed must be in the same state.
This fluid mixing tutorial, we are going to test a helium tank getting air pumped into one side and look at how the volume fraction changes as a function of time.
Launch the Flow Simulation Wizard to get the analysis started. Below are the selections for this example analysis.
Page 1 – Give the analysis a name
Page 2 – Set the units
Page 3 – Choose analysis type
Page 4 – Select fluids. Make sure all fluids used are the same type of fluid (i.e., Gases, Liquids, Non-Newtonian Liquids, Compressible Liquids, Real Gases, or Steam).
Page 5 – Wall Conditions
Page 6 – Initial Conditions
Add an Inlet Volume Flow to the inner face of one of the lids.
Add an Environmental Pressure to the inner face of the other lid.
Goal - to reach convergence as it solves for fluid behavior inside the tank.
Set the goals that you would like. For this example we will be looking at:
Cut Plot – Volume Fraction of Air
I hope you found this SOLIDWORKS Flow Simulation tutorial helpful. Check out more fluid studies below.
Understanding the Tesla Valve Using SOLIDWORKS Flow Simulation
Customizing SOLIDWORKS Flow Simulation Feature Tree Categories
Different Pressures in SOLIDWORKS Flow Simulation
Pressure Potential in SOLIDWORKS Flow Simulation Explained
About Tashayla Openshaw
