SOLIDWORKS Electrical Color to Number Conversions
Article by John Lieber on Jan 19, 2021
When defining wires, cables, and cable conductors, we routinely define the color. When using the SOLIDWORKS Electrical Application, it is pretty easy as we are presented with the colors in ‘named’ form (e.g., Red, White, Blue, etc.).
SOLIDWORKS Electrical Application Colors
However, if you happen to be using an Excel spreadsheet to define your wires or cable properties instead of using the name, we use a number.
SOLIDWORKS Electrical Colors in an Excel Spreadsheet
Below you will find a conversion chart for the color/name to numbers as well as an image to help you determine the numbers for all the colors that are not named but numbered.
Color to Number Conversion Chart for SOLIDWORKS Electrical
* - Color 7 is unique because when used for lines and text it will switch between black and white automatically based on the background color.
The rest of the colors are not labeled with ‘names’ but are available for use in SOLIDWORKS Electrical. Below is an image that shows the colors and their nearby numbers.
SOLIDWORKS Electrical Color Palette
Expand Your SOLIDWORKS Electrical Skillset
SOLIDWORKS Electrical Symbol Attributes
How to Add a PLC to Your SOLIDWORKS Electrical Project
Wrapping Attribute Text in SOLIDWORKS Electrical
About John Lieber
Johnathen is a Sr. Applications Engineer at our GoEngineer with over 15 years of technical experience, 13+ of which has focused on SOLIDWORKS. He has a unique perspective of having worked as a SOLIDWORKS Application Engineer and Trainer, which fosters an understanding of the user requirements with the system capabilities, allowing for quick resolution to business problems. Johnathen has experience in business process development, configuration, administration, training, installation, software development, and troubleshooting. His training style is focused on simplicity for the end user and administrators while providing excellent functionality.
View all posts by John Lieber
