SOLIDWORKS Designed Custom Exhibition Table
Article by Matthew Kusz on Apr 04, 2025
To display her pottery at an upcoming exhibition, my wife asked me to design and build custom oval tables that would be easy to assemble and transport between shows. Since I have designed tables before, I had some ideas, so I opened SOLIDWORKS and got to work.
SOLIDWORKS CAD Design
I started with the oval top.
Oval Tabletop Modeled in SOLIDWORKS
The large top makes it challenging to store in a small area, so cutting it in half helps reduce the footprint when packing it in an SUV or van.
Half of an Oval Table Designed in SOLIDWORKS
Next, I need hardware to bind the two haves together. So, I roughed out the holes for the hardware.
SOLIDWORKS Exhibition Table Hardware Design
I’ll add slots for removable biscuits to ensure proper alignment.
SOLIDWORKS Slots Exhibition Table Design
Now, I want to add a slot on the bottom of the table for the frame that will support the tabletop.
SOLIDWORKS Table Design Slot for Frame
Now that the top is done, I can make the two legs. I love symmetrical designs. I can create one part that works for both sides, keeping the design simple and elegant.
Folding Table Leg Design in SOLIDWORKS
To keep the design easy to assemble, I need to make cuts for the cross members that will support the tabletop and add rigidity to the legs.
SOLIDWORKS Table Leg Design
Then, I'll need one more slot that is lower, but this is for one cross-member.
Create Slots in SOLIDWORKS for a Table Leg Design
Let’s put these in a SOLIDWORKS assembly and see how they look.
Custom Table Design in SOLIDWORKS
I can use the information I gather using the measure tool to determine the size of the cross supports.
First, the tabletop cross supports that go just under the top of the table.
Support Structure Designed in SOLIDWORKS
Then, I’ll design the center support for the slot I added near the bottom of the legs.
Center Supports Designed in SOLIDWORKS
To guarantee this won’t fall apart, I added a few holes in this support for wedges to hold them in place, providing strength without additional hardware.
Now, I'll add these to the assembly, and see how things look.
DIY Table Design in SOLIDWORKS
Finally, I’ll make those simple wedges for the bottom cross member.
Table Wedge Designed in SOLIDWORKS
After assembling all the files in SOLIDWORKS and making some tweaks, it is time to order the wood and fasteners.
Custom Exhibition Table Designed in SOLIDWORKS 3D CAD
Since I'm making three different sized tables I was able to configure the features and sketches in the parts to create all the sizes.
Here is the type of hardware I used to bind the two tabletop halves together.
Hardware for Custom Designed Exhibition Table Designed Modeled in SOLIDWORKS
Assembling the Tables at the Museum
After the tables were built and finished, we arrived at the museum to set up the displays.
First the tabletop.
Then the legs, cross supports, and wedges,
Assembling Custom Exhibition Tables Modeled in SOLIDWORKS
Now, I’ll place the tabletop on the legs.
Custom Exhibition Table SOLIDWORKS Design
And here is the final result!
 SOLIDWORKS Custom Art Exhibition Tables for Pottery Display
My wife calls it ‘dad’ humor when I say this how I support her work. Now, on to the next project!
Want more SOLIDWORKS DIY? Check out other projects from our talented engineering team below. Additionally, join the GoEngineer Community to participate in discussions, create forum posts, and answer questions from other SOLIDWORKS users.
SOLIDWORKS CAD Cheat Sheet
SOLIDWORKS at Home: DIY CAD Projects
Full Iron Man Helmet Project
Wonder Woman Costume Comes to Life with 3D Printing, 3D Scanning, and 3D Design
SOLIDWORKS Backyard Design Project
Designing a Trailer Using SOLIDWORKS Weldments
VIEW ALL SOLIDWORKS ARTICLES
About Matthew Kusz
View all posts by Matthew Kusz
