Has the SOLIDWORKS Composer watermark appeared while using a network license? If so, check the three areas listed in this article to re-establish your license information and remove the SOLIDWORKS Composer watermark from the background of your project.
To verify that you are using the correct serial number for SOLIDWORKS Composer, first consult with your CAD Admin if any changes have been recently made to your company’s products. Then check which serial number is being used for Composer.
Your computer communicates to a local server to pull a license of Composer. It uses a client version of the License Manager to accomplish this. This program must be able to communicate to the correct server hosting the seat of Composer. To check this, follow the steps below.
It may be that the license information on the server hosting your Composer seat is out of date and needs to be reactivated. Get with your IT to perform the following steps.
To remove the watermark from a SOLIDWORKS Composer file that was either opened in the non-licensed version or from a trial period:
Note: Watermarks may still be shown in view previews in the Views tab. To remove the watermark from the view previews, activate and update each view or click the redraw views button.
Mirror Parts with Symmetrize in SOLIDWORKS Composer
Export High-Quality Videos with SOLIDWORKS Composer
Saving SVG as Webpage HTML in SOLIDWORKS Composer
SOLIDWORKS Composer 2020 What’s New
About Benjamin Modic
Ben was raised in Metro Detroit and went to school for Mechanical Engineering Technology at Ferris State University. He started using SOLIDWORKS in 2010 while in school after joining the Formula SAE program. After graduation, he spent time working as an engineer in the automotive, sporting goods, and furniture industries in Michigan. Ben moved to Utah to join the GoEngineer team in 2015 and has since focused on leading simulation support for our customers.
