SOLIDWORKS CAM Features & Allowable Operations
Article by Martin Bucholz on May 21, 2021
The core of SOLIDWORKS CAM is its feature recognition engine, but these features are not the same extrudes and revolves we are used to with SOLIDWORKS. Let's take a tour through the feature types and allowable operations used by SOLIDWORKS CAM.
In this article we'll cover the following 10 SOLIDWORKS CAM features as well as their allowable operations:
  1. Face features
  2. Open pocket
  3. Pocket
  4. Slots
  5. Corner slots
  6. Boss
  7. Hole
  8. Open profile
  9. Engraved feature
  10. Curve feature
GoEngineer Video SOLIDWORKS CAM and CAMWorks: What's New in 2021   Related Video  >> SOLIDWORKS CAM and CAMWorks: What's New in 2021
Face Features
Face Feature is an open area to be cut using a Facemill. SOLIDWORKS CAM moves the tool parallel to the selected face past the boundaries of the feature. Face features can be defined by faces, edges, or closed, non-intersecting sketches.
SOLIDWORKS CAM Face Feature
Allowable operations: Rough Mill, Contour Mill
Open Pocket
An Open Pocket is an area to cut that is open on all sides. This is similar to a face feature but includes islands/ bosses or an area that you want to work around. Open pockets can be defined by faces, edges, or closed, non-intersecting sketches.
SOLIDWORKS CAM Open Pocket Feature
Pocket
Pocket is a recessed area where none of the sides are open to air. The tool will stay within the edges of the feature. Pockets can be defined by faces, edges, or closed, non-intersecting sketches.
SOLIDWORKS CAM Pocket Feature
Allowable operations: Rough Mill, Contour Mill, Thread Mill, and all Hole Machining Operations
Slot
Slot is a recessed area with one side open to air. SOLIDWORKS CAM will detect the open side and allow the tool to travel beyond the edge to ensure the feature is fully cut. Slots can be defined by faces, edges, or closed, non-intersecting sketches.
SOLIDWORSK CAM Slots Feature
Corner Slots
Corner Slots are recessed areas with two sides open to the air. SOLIDWORKS CAM will identify the open sides and allow the tool to travel beyond the edges of the feature on the open sides to ensure the geometry of the feature is fully cut. SOLIDWORKS CAM distinguishes between Rectangular and Irregular shaped corner slots. Corner slots can be defined by faces, edges, or closed, non-intersecting sketches.
SOLIDWORKS CAM Corner Slot Feature
Boss
Boss is a raised area of material to be cut around. SOLIDWORKS CAM distinguishes between Rectangular, Circular, Irregular, and Obround shapes. Bosses can be defined by faces, edges, or closed, non-intersecting sketches.
SOLIDWORKS CAM Boss Feature
Allowable operations: Contour Mill, Thread Mill
Hole
Hole is a round recess to a depth or through the stock using point-to-point tools. SOLIDWORKS CAM recognizes blind and through holes. Holes can be defined by faces, edges, or circular sketches.
SOLIDWORKS CAM Hole Feature
Allowable operations: Center drill, Drill (including peck), Countersink, Bore, Ream, Tap, Rough Mill, Contour Mill, Thread Mill
Open Profile
The Open Profile feature allows the tool to follow part edges or sketch lines. The tool will be offset from the edge or sketch line by the radius of the tool. This feature is commonly used to make a cut along the side of a part. This feature can be used on open, non-intersecting edges and sketches that are parallel to the current Mill Part Setup.
SOLIDWORKS CAM Open Profile Feature
Engrave Feature
With Engrave Feature, the tool center will follow the selected sketch entities, which can include edges, lines, arcs, splines, and text objects. Sketches can be open, closed, or self-intersecting.
SOLIDWORKS CAM Engrave Feature
Curve Feature
With Curve Feature, the tool center will follow the selected 2D or 3D sketch, edge, or curve in three dimensions. This is often useful for chamfers. Selected entities can be open, closed, or self-intersecting.
SOLIDWORKS CAM Curve Feature
Learn More About SOLIDWORKS CAM
SOLIDWORKS CAM & CAMWorks CommandManager Icon Reset
SOLIDWORKS CAM Overview: Standard VS. Professional
Managing Your SOLIDWORKS CAM Add-ins
What Do You Know About SOLIDWORKS CAM? Let's Test It!
About Martin Bucholz
Marty has been in the manufacturing industry since around 2000, doing a bit of everything, Tool & Die machining, assembly work, inventory control, shipping and receiving, even sweeping the floors. He started using SOLIDWORKS as a product designer in 2007 for Cast Aluminum solutions (formerly a division of Watlow) designing customized heating solutions for food service, medical, and semiconductor industries. Then in 2014 he moved over to the VAR side of things and has been doing tech support and training for SOLIDWORKS, SOLIDWORKS PDM and now SOLIDWORKS CAM and CAMWorks. Outside of the office Marty is an avid gamer from board games to video games, even helping to plan and run a local Tucson gaming convention. When he is not doing that you can find him walking dogs at the Pima County Animal Care Center.
View all posts by Martin Bucholz
