SOLIDWORKS Autotrace Tool Tutorial
Article by Nick Stanley on Jul 19, 2023
The SOLIDWORKS Autotrace tool is an add-in that can help users quickly create 3D objects from an imported picture. The 3D logo below was created using this tool.
SOLIDWORKS Autotrace Tool Used to Create 3D Logo
How to Access Autotrace
Access the Autotrace feature by enabling it in Add-Ins.
Activate SOLIDWORKS Autotrace Tool via Add-Ins
Checking the left check box will activate Autotrace. Checking the right check box will automatically launch it on start up.
How to Use Autotrace
To start, open a blank new document.
Open New SOLIDWORKS Document
Then, select which plane you want to begin with and start a new Sketch.
Start New SOLIDWORKS Sketch
On the menu bar, select Tools Sketch Tools Sketch Picture...
Sketch Picture Option in SOLIDWORKS Tools Menu
Select the sketch image you want to import from the File Explorer window and select Open. The sketch picture will import into the selected plane.
SOLIDWORKS Autotrace Sketch Picture
With the Autotrace add-in turned on, notice that there is now a "next arrow" in the Sketch Picture dialog.
Here, we can use intelligent tools to automatically select the outline of the logo.
Next Arrow SOLIDWORKS Sketch Picture
In this case, we'll primarily use the Trace Selection tools.
SOLIDWORKS Trace Setting Selection Tools
Let's start by using the rectangle selection tool to select most of the image in a single go.
SOLIDWORKS Rectangle Selection Tool
The result of the initial selection is decent, but it looks like it needs some refinement as we are getting some odd artifacts on the DS selection of the logo.
Using Selection Tools in SOLIDWORKS
To adjust the selection, use the aptly named adjustments section. In this case, we'll use the Recognition tolerance to fix up these lines.
Recognition Tolerance Levels in SOLIDWORKS
Next, click the Apply button to set the selection as permanent. This can be useful as it will allow us to select more from the image. As you can see, the inside loop of the O didn’t get selected.
SOLIDWORKS Sketch Picture Apply Button
Using the dropper selection tool, choose a point in the center of the O and select Begin Trace, repeating until everything is selected.
Begin Trace in SOLIDWORKS
The tool will take care of the bulk of the selection very quickly, but the tool isn’t perfect and will often need refining such as this resulting sketch on the D.
Using SOLIDWORKS Autotrace
While the tool will quickly take care of the bulk of the selection, it isn't perfect and can require some refining. (Shown on the letter D below)
After editing the sketch and removing any odd portions, the result will be a complete sketch that can be extruded.
Extrude SOLIDWORKS Sketch
Now that we have our sketch, we can select the extrude feature and produce the 3D extruded logo.
Boss-Extrude SOLIDWORKS Sketch
I hope you found this SOLIDWORKS Autotrace tool tutorial helpful. Check out more SOLIDWORKS tips and tricks below.
SOLIDWORKS CAD Cheat Sheet
More SOLIDWORKS Tutorials
Why SOLIDWORKS Mates Can Cause Slow Assemblies
Show Sheet Metal Bend Lines in a SOLIDWORKS Drawing
SOLIDWORKS Face Curves Explained
How to Change Orientation of an Existing SOLIDWORKS Part
SOLIDWORKS: Creating a Derived Centerline in a Twisted Sweep
VIEW ALL SOLIDWORKS TUTORIALS
About Nick Stanley
Nick Stanley is a SOLIDWORKS Technical Support Specialist at GoEngineer.
View all posts by Nick Stanley
