How to Show eDrawings Markups in SOLIDWORKS
Article by GoEngineer on Jul 19, 2015
Currently, eDrawings Markup is available for SOLIDWORKS drawings but not part or assembly files. Here are the steps to show eDrawings Markups or any other tool in eDrawings to show in SOLIDWORKS Drawings files.
In this example, we will focus on the Markup tool but this process can be applied to any of the eDrawing tools.
  1. In eDrawings, open a SOLIDWORKS Drawing file by going File > Open > Browse to file then Open. Here is the drawing we will use as our sample and how it looks once opened in eDrawings.
  2. Click Tools > Markup or select the Pencil Icon on the left side.
    eDrawings Markup Tool
  3. A Markup diagram is located on the left side of the screen with different types of markup icons. To add a Markup, click on one of the icons and place it anywhere you like in the graphics area.
    eDrawings Markup Comments for SOLIDWORKS
  4. Here is what it looks like in eDrawings with the Markups highlighted I used:
    eDrawings Markup Example
  5. After you are finished adding the Markups, click File > Save Markup:
    Save Markups in eDrawings
  6. Select Markup To Save window appears. Click Ok.
    Select Markups to Save in eDrawings for SOLIDWORKS
  7. Save As window appears. Save the document with your name choice. Note: You do not need to save the part:
    Save As Window in eDrawings Markups
  8. Then, exit eDrawings, and a popup window will appear saying do you want to save changes? Select Yes.
    Save Changes in eDrawings for Markups
  9. In SOLIDWORKS, open the same SOLIDWORKS Drawings file used in eDrawings in order to create the markup. Note: this is the drawing file, not the markup file.
    eDrawings SOLIDWORKS Drawing File
  10. Open the same SOLIDWORKS Drawings file used in eDrawings in order to create the markup. Note: this is the drawing file, not the markup file:
  11. In SOLIDWORKS, there are a couple of options depending on how your SOLIDWORKS is set up if the Markups do not display automatically.
    1. Click Tools, eDrawings Markup File, A Open window is displayed. Select the Markup file that you saved via eDrawings and click Open. The markups created in eDrawings appear in the drawing....
      or if that isn’t an option then;
    2. Click Tools > Options > on Systems Options tab go to Feature Manager and select Show for eDrawings Markups, then OK:
      SOLIDWORKS FeatureManager eDrawings Markups
  12. The final result in SOLIDWORKS will look like the following:
    eDrawings Markups in SOLIDWORKS Drawings Tutorial
Learn More about eDrawings
SOLIDWORKS eDrawings for Mobile: Oh, The Places You'll Go
eDrawings Professional - Add Custom Stamps
GoEngineer YouTube Video SOLIDWORKS Tutorial - Publish eDrawings on the Web SOLIDWORKS Tutorial - Publish eDrawings on the Web
GoEngineer video  SOLIDWORKS eDrawings - Capabilities SOLIDWORKS eDrawings - Capabilities
 GoEngineer video SOLIDWORKS eDrawings Tutorial - Support for Configurations SOLIDWORKS eDrawings Tutorial - Support for Configurations
