How to Print Current Screen Image in SOLIDWORKS
Article by GoEngineer on Feb 01, 2017
In this step-by-step tutorial, learn how to print a current screen image in SOLIDWORKS
  1. Right-click on the View in the FeatureManager Design Tree that you want to print and Zoom to Selection.
    Zoom to Selection Option in SOLIDWORKS
  2. Go to File then Print.
    How to print current screen image in SOLIDWORKS
  3. The Print dialog box will appear. Under the Print range option, select Current screen image and check the box next to it that says Selection, then select OK.
    Current Screen Image Selection in SOLIDWORKS
  4. The Print Selection pop-up will appear.
    SOLIDWORKS Print Selection Model Scale
  5. Select Custom scale and enter in the values you desire. Notice that a semitransparent frame will appear. You can move the frame by clicking once on it and dragging. This is how to position what you want to print. Everything inside the frame will print. Select OK.
    SOLIDWORKS Print Selection Custom Scale Option
This is what you will see if you print it to an image or PDF or if you print it to a printer.
 Print image or PDF from SOLIDWORKS
More SOLIDWORKS Tutorials
Saving a SOLIDWORKS File as a PDF vs Print to PDF
Creating Reference Planes in SOLIDWORKS: Offset, Angle, Mid, & Cylindrical Surface
Smart Explode Lines in SOLIDWORKS Explained
2 Ways to Reference a Cross-Section in SOLIDWORKS
Creating and Adding Weld Beads in SOLIDWORKS Models & Drawings
