One of the most frequently asked questions from Flow Simulation users is, will my electronics product overheat under normal and everyday conditions? SOLIDWORKS Flow Simulation software is specifically suited to answer this question. So if you currently own SOLIDWORKS Flow Simulation software, or are considering purchasing a new license below are the differences between regular Flow Simulation and the Electronics Cooling Module add-in.
SOLIDWORKS Flow Simulation is very good at simulating the cooling scenarios of electronic equipment on its own. The Electronics Cooling Module add-in enhances Flow Simulations abilities to simulate electronics cooling in several different cases making setting up an electronics cooling flow simulation easier on the user. We will go over these cases together below.
Computer Chips are found in almost every electronic product these days and are generally one of the main sources of heat for these products. To obtain accurate heating/cooling information on these chips from Flow Simulation, it is extremely important to set the chips up as accurately as possible in Flow Simulation. That being said Flow Simulation does use a simplified representation of computer chips because of the complexity of these packages, but as you will see the Electronics Cooling Module uses a more complicated and closer to real-life representation.
Image courtesy of wisegeek.com
Joule Heating or resistive heating is generated as electricity passes through a conductor.
Image courtesy of comsol.com
Printed Circuit Boards have unique thermal properties because of their layered design. These boards conduct heat differently through their thickness than in the plane of the board.
Heat Pipes in electronics use the superior thermal conductivities of liquid over solid matter to transfer heat more efficiently from one place to another within the electronics enclosure.
On top of the features specified above, the Electronics Cooling Module has a much more extensive engineering database with a lot more material, fan, and component information than just regular Flow Simulation.
Image courtesy of Wikimedia.org
What it comes down to is that while it is possible to in most cases to get the same results, in the end, using Flow Simulation, how much more time and effort do you want to put into making sure that those results are accurate? The Electronics Cooling Module will make setting up an accurate Flow Simulation analysis much more efficient and convenient than it is without it.
Customizing SOLIDWORKS Flow Simulation Feature Tree Categories
Different Pressures in SOLIDWORKS Flow Simulation
Backspin is Important to your Basketball Free Throw! A SOLIDWORKS Simulation Study
About Taran Packer
