How to Install SOLIDWORKS Add-in Licenses
Article by Zach Brown on Oct 03, 2022
In this guide, we show how to install SOLIDWORKS add-in liceneses by adding serial numbers to the SOLIDWORKS Installation Manager for your purchased SOLIDWORKS add-ins.
Perform a Modify Installation
To add serial numbers to the SOLIDWORKS Installation Manager, you will have to perform a Modify installation through the Programs and Features utility in Windows. To find the Programs and Features utility, open the Control Panel. Next, select Programs and Features from the Programs section.
SOLIDWORKS Programs and Features Options
From the list of installed programs, find the SOLIDWORKS installation, select it, and click Change
Note: Do NOT Select Uninstall. If the only option available is Uninstall, then your SOLIDWORKS was installed using an Administrative Image. Refer to the end of this article for next step details for Administrative Images.)
The SOLIDWORKS Installation Manager will now launch. Select the top option, Modify the individual installation, and click Next.
Install SOLIDWORK Add-In Licenses
On the Serial Number screen of the Installation Manager, you can now enter the serial number next to the SOLIDWORKS add-in you want to install. (CRTL+V will paste the serial number into the six boxes.)
Installing SOLIDWORK Add-in Licenses
After entering the new serial number, click Next through the rest of the installation screens without making any further changes. Accept the terms of SOLIDWORKS, then click Modify Now to complete the process.
SOLIDWORKS Installation Manager Add-In Tutorial
When selecting your SOLIDWORKS installation in the Programs and Features dialog, if the only option available to you is Uninstall then your license was installed with an Administrative Image.
You will need to use the Administrative Image Option Editor and click Change to add serial numbers, then deploy the image to your computer.
SOLIDWORKS Add-in Installation Administrative Images
I hope you found this tutorial helpful. To learn more about SOLIDWORKS, check out the links below.
More SOLIDWORKS Tutorials
Decoding Your SOLIDWORKS Serial Numbers
SOLIDWORKS License Manager Tutorial
How to Update Your SOLIDWORKS License Server with Newly Purchased Seats
Recovering a Hung SOLIDWORKS Network License
VIEW ALL SOLIDWORKS TUTORIALS
About Zach Brown
View all posts by Zach Brown
