CAMWorks has four different licensing options: Dongle, Standalone, FlexLM Network, and FNO. These four license options are all used through the CW License Manager utility. To access this utility, go to the Start menu and search for the CW License Manager.
Note: To make changes to the CW License Manager you must run it as an Administrator, or the changes will not take effect.
For instructions to install your CAMWorks license, select the license type you purchased from the list below to jump to the instruction for that type.
The four different types of CAMWorks licenses are:
Note: Please ensure you have the latest version of the CAMWorks License Manager.
If you have not installed this update, please download it from www.camworks.com.
The Dongle tools are now integrated into the License Manager.
DOWNLOAD CAMWORKS LICENSE ACTIVATION GUIDE
We suggest reading the Activation document before proceeding. Complete the quick login information, and the download will be available.
For software downloads, go to www.camworks.com and use your existing CAMWorks account or, if you have no account, you will need to register for a new account. You must register to create your own company account. Save this information, as you will use this account for future downloads of the software. It may take up to 48 hours to activate the new account. Please contact Technical Support if you have trouble.
Get the latest versions by logging on to the CAMWorks website
The Dongle license option will run the CAMWorks license from a USB dongle key. This dongle key requires a .COD file to update the dongle key. The .COD file is the license file for this license type. To activate the Dongle license type, follow the steps below.
If you are installing a Standalone FlexLM license, you will be issued a license file, which is used on the computer where the software is installed. When you receive a new license file for the installation, follow the below steps to request and, once received, activate the new license file.
We suggest reading the Activation document before proceeding. Complete the quick login information, and the download will be available. For software downloads, go to www.camworks.com and use your existing CAMWorks account or, if you have no account, you will need to register for a new account. You must register to create your own company account. Save this information, as you will use this account for future downloads of the software.
If your computer has Outlook email capabilities, click the Outlook button and send the email with a subject line that includes your Copy Protection Device Serial Number (CPD) and with the attachment to gt.register@hcl.com. If this computer does not have email capabilities, click the Other button.
Note the location of the file containing your information, then email the file in an attachment to gt.register@hcl.com from another computer. Make sure to include your Copy Protection Device Serial Number (CPD) in the subject line of the email. Click Close to exit the request form. You can also close the License Manager. CAMWorks will not run until you receive the license file and activate the license.
If you are updating a floating network license, you will be issued a license file, which is used to update only the Network Server. When you receive a new license file for a floating network installation, follow the below steps to activate the new license file.
We suggest reading the Activation document before proceeding. Complete the quick login information and the download will be available. For software downloads, go to www.camworks.com and use your existing CAMWorks account or, if you have no account, you will need to register for a new account. You must register to create your own company account. Save this information, as you will use this account for future downloads of the software. It may take up to 48 hours to activate the new account. Please contact Technical Support if you have trouble.
For existing customers, ensure you have the latest version of the CAMWorks License Manager installed before requesting the license file.
The license request file required for generating the license must be created directly on the computer where the license will reside. If the license request file is created when running the License Manager via remote communications software and submitted to gt.register@hcl.com, an invalid license will be generated. Hence, ensure that physical access is available to the computer on which the license will reside and will be consequently used at least during the stage of generating the License Request File.
Once the license file is emailed back, the activation of the license can be performed remotely if physical access is not possible.
If your computer has Outlook email capabilities, click the Outlook button and send the email with a subject line that includes your Copy Protection Device Serial Number (CPD) and with the attachment to gt.register@hcl.com. If this computer does not have email capabilities, click the Other button. Note the location of the file containing your information, then email the file in an attachment to gt.register@hcl.com from another computer. Make sure to include your Copy Protection Device Serial Number (CPD) in the subject line of the email. Click Close to exit the request form. You can also close the License Manager. CAMWorks will not run until you receive the license file and activate the license.
New Installation of the license once you receive the license file from gt.register@hcl.com:
On the Client computer, open the CAMWorks License Manager utility by right-clicking on the icon and selecting Run as Administrator. The CAMWorks License Manager dialog box is displayed.
Click the License Setup tab.
Updating the new license once you receive the license file from gt.register@hcl.com:
An FNO license is a new option provided to us by CAMWorks. Like other online activation licenses, this license type will allow you to request activation from an automated server.
There are two types of FNO licenses: Standalone and Floating Network.
Both options will lock the license to their designated machine, (standalone for client computers, floating network for server computers) that will provide the license to the client machines.
To activate this license option, you will receive an activation code in the email you registered your account with, or the email of the primary contact who purchased the license.
An easy way to identify which FNO license type your activation code is, Standalone FNO license codes will begin with X11, and Network codes will start with X22.
Note: This license option may not be available to everyone at the time this article was published. This license type is also restricted to CAMWorks 2022 and newer.
Note: Please make sure you have the latest version of the CAMWorks License Manager. If you have not installed this update, please download it from www.camworks.com.
We suggest reading the Activation document before proceeding. Complete the quick login information and the download will be available. For software downloads, go to www.camworks.com and use your existing CAMWorks account or, if you have no account, you will need to register for a new account. You must register to create your own company account. Save this information as you will use this account for future downloads of the software. It may take up to 48 hours to activate the new account. Please contact Technical Support if you have trouble.
Right-click on the License Manager icon, click Run as Administrator, then click the License Setup tab.
In the License Method dropdown, make sure Nodelocked (Standalone) is selected.
The FNO license option is a new option provided to us by CAMWorks. Like other online activation licenses, this license type will allow you to request activation from an automated server. There are two types of FNO licenses: Standalone and Floating Network.
Both options will lock the license to their designated machine (standalone for client computers, floating network for server computers) that will provide the license to the client machines.
To activate this license option, you will receive an activation code to you’re the email you registered your account with, or the email of the primary contact who purchased the license.
Note: This license option may not be available to everyone at the time of this article’s publication date. This license type is also restricted to CAMWorks 2022 and newer.
Note: Please make sure you have the latest version of the CAMWorks License M<anager. If you have not installed this update, please download it from www.camworks.com The Dongle tools are now integrated into the License Manager.
For software downloads, go to www.camworks.com and use your existing CAMWorks account or, if have no account, you will need to register for a new account. You must register to create your own company account. Save this information as you will use this account for future downloads of the software. It may take up to 48 hours to activate the new account. Please contact Technical Support if you have trouble.
Right-click on the License Manager icon, select Run as Administrator, then click the Server Settings tab.
In the Server License Method dropdown, make sure Online Activation is selected.
Editor's Note: This article was originally published in August 2022 and has been updated for accuracy and comprehensiveness.
Setting Up Your CAMWorks License File
Suppressing Features in CAMWorks for Better Tool Paths
SOLIDWORKS CAM and CAMWorks CommandManager Icon Reset
About Nick Stanley
Nick Stanley is a SOLIDWORKS Technical Support Specialist at GoEngineer.
