This guide explains everything you need to know about how to create a SpeedPak in SOLIDWORKS.
In an assembly file, you can derive a SpeedPak configuration from an existing configuration.
To create a SpeedPak:
A SpeedPak configuration is created as a child of the original configurations. It is identified with
in the ConfigurationManager, and _speedpak is appended to its name.
No components appear in the FeatureManager design tree. The assembly icon
at the top of the tree indicates that the active configuration is a Speedpak configuration.
In the graphics area, when you move the pointer over the assembly, only the faces and bodies you selected for the SpeedPak are visible and selectable in the region surrounding the pointer.
To see this behavior, make sure the driver for your graphics card is up to date.
Assembly without pointer
Pointer over assembly
Note that many internal components are no longer visible, as they were not included in the Speedpak configuration.
You can create SpeedPak configurations for subassemblies from within a parent assembly. You can choose to include only graphics, or include mated faces, edges, and points as resolved geometry.
You can insert an assembly with a SpeedPak configuration into a higher level assembly.
To insert a SpeedPak:
In the higher level assembly, insert the subassembly by any of the following methods:
Use the Insert Component PropertyManager. Select the SpeedPak configuration under Configurations in the Open dialog box.
Drag from the File Explorer tab in the Task Pane.
Drag from the Design Library in the Task Pane.
Drag from Windows Explorer.
Ctrl + drag within the assembly to insert additional instances of existing components.
In the region surrounding the pointer, only the faces and body you selected for the SpeedPak are visible. They are the only items you can select for operations such as mating.
How to Save Annotation Properties in SOLIDWORKS
Missing Cosmetic Threads and How to Fix Them in SOLIDWORKS
