Grayed Out CommandManager CAMWorks
Article by Nick Stanley on Mar 03, 2019
This tutorial explains what to do when your CommandManager is grayed out in CAMWorks
When you first connect to the FlexLM server for CAMWorks, the floating license by default has the CAMWorks Modules turned off for your license. With your modules inactive your CommandManager will be grayed out.
Grayed Out CommandManager in CAMWorks
To access the features of CAMWorks, you will need to activate your modules. To do so, click on the Help dropdown menu at the top of the SOLIDWORKS/CAMWorks menu.
CAMWorks Grayed Out CommandManager Help
After selecting the Help dropdown menu, select your CAMWorks (year) in the dropdown. (For this example I am using 2019.) Once you select the CAMWorks year, select License Info…
CAMWorks License Info Location
After selecting the License Info… button, a pop up will launch. This pop up is your license info. There will be a column of check boxes and next to each the module that is available on your CAMWorks floating license.
Depending on your package of CAMWorks, some of these boxes may be unavailable to you. Select the Select All button or select each indivually.
CAMWorks License Info Selections
After selecting the packages that you would like to use, select OK and it will add the modules for this session of CAMWorks.
If you would like to add the modules on start up, you can select the Select All button which will add all to start up, or you can select the Update Licenses button to add the specified modules for start up.
CAMWorks License Info Options Causing Grayed Out CommandManager
Again, the modules available to select may appear differently depending on your version of CAMWorks.
When you are satisfied with your selection select the OK button to close the pop up license info window.
CAMWorks CommandManager No Longer Grayed Out
Your CAMWorks features on the CommandManager are now colored and ready to be used. Note that not all will appear with color as they will become available through the CAMWorks workflow when programming a toolpath.
I hope you found this tutorial for solving a grayed out CommandManager in CAMWorks helpful. Check out more SOLIDWORKS CAM and CAMWorks tips and tricks below.
CAMWorks Air Segment Offset Explained
How to Set Up a Firewall Exception for CAMWorks Teksoft.exe
SOLIDWORKS CAM and CAMWorks CommandManager Icon Reset
Add Materials to CAMWorks Material Library
Quickly Constrain a CAMWorks Toolpath Using Split Line
About Nick Stanley
Nick Stanley is a SOLIDWORKS Technical Support Specialist at GoEngineer.
View all posts by Nick Stanley
