Figure #1 – DriveWorks Professional Administrator Dialog
Specification Settings:
The specification settings task provides the ability to control the naming and folder location of specifications which are created by running a project (see Figure #2).
Figure #2 – Stage: Specification Control – Specification Settings
The settings controlled in this section are the following:
- Specification Name – Gives each specification a unique name.
- Specification Path – This setting defines the location from which the DriveWorks specification files will be stored. This must be a location unique for each specification made.
- Specification Tags – Used when multiple Autopilot machines are in use.
- Additional Folders – Set up rules for additional folders used in the specification.
Specification Properties:
The specification properties task provides the ability to have additional columns of information appear in the Specification Explorer for specifications created from the active project (see Figure #3).
Figure #3 – Stage: Specification Control – Specification Properties
Specification Macros:
Specification Macros can be applied to Macro Buttons on the user Form or triggered from the Specification Flow, Specification Timers, or Drive3D Click Macro Entities to run set Tasks that can have parameters passed into them using Rules or Connections (see Figure #4).
Figure #4 – Stage: Specification Control – Specification Macros
Several macros are provided for you to use via the Toolbox on the right side. You can add, edit, rename, delete, copy/paste, and categorize the macros to make it easier to manage if you have a large number.
Specification Flow:
The specification flow task provides the ability to customize the behavior of specifications created by running a project. It allows the creation of the navigation buttons that appear on the user forms.
Furthermore, you decide which Users or Teams have permission to perform actions on a specification.
It is possible to completely replace it with a custom one of your own design to gain complete control over the specification process (see Figure #4).
