Use SOLIDWORKS Indent Feature in an Assembly
Article by Tashayla Openshaw on Jan 08, 2024
In this SOLIDWORKS tutorial, we demonstrate how to create indents at the assembly level. In this example, we have an assembly of a plate and three pieces that intersect with the plate.
SOLIDWORKS Indent Feature Tutorial
The goal is to change the geometry of the plate to encompass the three pieces on the bottom.
SOLIDWORKS Assembly Modeling Indent Feature Tutorial
To do this, we'll use the Indent feature. Start by editing the plate part in the context of the assembly by right-clicking on the part and selecting the Edit Part icon.
Edit Part Icon in SOLIDWORKS
This gives us access to the standard CommandManager typically seen in part modeling. You can tell we are editing a component by the icons on the left of any tab in the CommandManager (1), and we can see which part is being edited by its blue text in the FeatureManager Design Tree (2).
Edited Part in SOLIDWORKS FeatureManager Design Tree with Blue Text
Start the Indent command by going to Insert > Features > Indent...
How to Access the Indent Feature in SOLIDWORKS
In the Target body region, select the plate and choose Remove selections. Then, under Tool body region, we'll select one of the pieces we would like indented in the plate. Keep in mind that the Indent feature will need to be performed separately for each part; we won’t be able to select all three in one feature when working in a top-down assembly model.
How to Use the SOLIDWORKS Indent Feature in an Assembly
Once complete, we can exit Edit Component and open up the plate part separately to check that the features are appearing on the part file.
We can tell it is linked by the carrots next to each of the indent features in the FeatureManager Design Tree.
Tutorial Explaining the Indent Feature in SOLIDWORKS
I hope you found this SOLIDWORKS quick tip helpful. Check out more tips and tricks listed below. Additionally, join the GoEngineer Community to participate in the conversation, create forum posts, and answer questions from other SOLIDWORKS users.
SOLIDWORKS CAD Cheat Sheet
Want to take your SOLIDWORKS assembly skills to the next level? Enroll in the official SOLIDWORKS Assembly Modeling training course, which builds upon the Essentials lessons to provide instruction on advanced features and capabilities. Both online and in-person classes are available.
GoEngineer YouTube Video SOLIDWORKS Indent Feature Learn more about using the Indent Feature in a SOLIDWORKS assembly in our YouTube video!
More SOLIDWORKS Tutorials
SOLIDWORKS Top-Down Assembly Modeling Quick Tip
Top 10 SOLIDWORKS Tutorials of 2023
Managing External References in SOLIDWORKS Assemblies
SOLIDWORKS Indent Cut vs Combine/Subtract
Using SOLIDWORKS Copy with Mates
VIEW ALL SOLIDWORKS TUTORIALS
About Tashayla Openshaw
