SOLIDWORKS PDM Standard: How to Static Ports in SQL Express
Article by Miguel de Villa on Nov 30, 2023
This article outlines the steps on how to switch a named instance of SQL Express from the default dynamic ports to static port 1433 as outlined in S-051981. When an SQL Express server communicates over a dynamic port, it is allocated a free port number by the operating system rather than communicating exclusively over a specified port, also known as a static port. As a result, even when the appropriate firewall exemptions as seen below have been made for port 1433, client machines are unable to communicate with the server as the server is trying to listen over a blocked port.
Generally, it’s best practice to make the following Inbound/Outbound rules in the firewall to ensure connectivity between SOLIDWORKS PDM server components and PDM client machines.
  • TCP inbound: 25734-25735, 3030,1433, 1434
  • UDP inbound: 25734-25735, 3030, 1433, 1434
  • TCP outbound: 25734-25735, 3030, 1433, 1434
  • UDP outbound: 25734-25735, 3030, 1433, 1434
Setting up Static Ports
Example Instance Name: (STD_Express)
  1. Open the SQL Server 2014 ConfigurationManager
    Start Menu > Microsoft SQL Server 2014 > SQL Server 2014 ConfigurationManager.
  2. Open the TCP/IP protocol for the named SQL Instance the vault is using.
    SQL Server Network Configuration
    SQL Server Network Configuration > Protocols for (Instance Name)> Double-click on TCP/IP.
  3. Switch General Protocol settings to Enabled.
    General Protocol Setting Set as Enabled
  4. Under IP Addresses, we need to make sure that for IP1-IPall we use the following settings:
    SQL Express TCP Dynamic Ports
    1. TCP Dynamic Ports is cleared (Default value of 0 stands for dynamic ports enabled)
    2. TCP Port is set to 1433
  5. Select Apply and OK.
    Setting Static Ports SOLIDWORKS PDM
    In order to implement these settings, we need to stop restart the PDM Archive and Database server and SQL Server services.
    Stop Restart PDM Archive Database Server Warning
  6. Close the SQL Server 2014 ConfigurationManager.
  7. Open Task Manager > Services > Find the SOLIDWORKS PDM Archive Server service PDM and SOLIDWORKS PDM Database Server service.
    SOLIDWORKS PDM Task Manager Archive Server Service
    Right-click on each service and hit Stop.
    Stop SOLIDWORKS PDM Archive Server
  8. Open Task Manager > Services > Find MSSSQL$$Instance_Name
    PDM Standard Setting Static Ports SQL Express
    Right-click the SQL Server > Restart
    Restart SQL Server in SOLIDWORKS PDM Standard
  9. Restart the PDM Archive and Database Services. Right-click on the service > Start.
    Restart SOLIDWORKS PDM Archive Database Services
  10. Test accessibility by logging into the vault on the client as normal.
    SOLIDWORKS PDM Standard Demo Vault
Related SOLIDWORKS PDM Articles
SOLIDWORKS PDM Standard Vault SQL Express Broadcast Settings
SOLIDWORKS PDM Professional SQL Server Changes for 2022
SOLIDWORKS PDM Standard Automated SQL Backup
SQL Maintenance for SOLIDWORKS PDM Standard
About Miguel de Villa
Miguel de Villa is a SOLIDWORKS Elite Applications Engineer with a B.S. in Mechanical Engineering from the University of California, San Diego. He’s been working at GoEngineer since 2017 helping customers with all their SOLIDWORKS, Simulation and PDM needs. In his free time he enjoys working with his 3D printer, playing video games and building model kits.
View all posts by Miguel de Villa
