Have you ever had a dialog box not appear on your screen, causing SOLIDWORKS to become unresponsive? This can happen for a variety of reasons, including an external monitor being disconnected or even a malfunction in Windows.
So what can be done to resolve SOLIDWORKS off screen dialog boxes? There are a few different options; keep in mind that not all of these suggestions will resolve the issue, but they will be listed in order of difficulty, starting at the most simple fix.
#1. Windows Key + Arrow Keys
Hold down the Windows Key, while attempting different variations of the arrow keys. For example, if you used to have a monitor on the left side of your main monitor, hold down the Windows Key and push the right arrow key a few times to try and move the dialog to the right.
#2. F11 Key
Select the F11 key. This will change the main SOLIDWORKS screen to fullscreen mode.
#3. Modify Screen Resolution
Right-click on the Desktop and select Display settings. Try a couple of different values for Display resolution.
#4. Disconnect External Monitors
If there are multiple external monitors, disconnect one at a time. This can force dialog boxes that may be off screen onto connected screens or laptop screens.
If you're on a laptop and it is connected to a docking station, try disconnecting from that.
#5. Windows Key + P
Hold down the Windows Key and select P, for a laptop choose PC screen only.
#6. Reset SOLIDWORKS Dialog Registry Key
#7. Test in a Brand New Windows User Account
Make sure not to clone the current account, create one from scratch and test the behavior again.
#8. Clean Uninstall and Reinstall of SOLIDWORKS
I hope you found this tutorial helpful. Check out more SOLIDWORKS tips and tricks on our YouTube channel and listed below.
How to Use Layers in SOLIDWORKS Drawings
SOLIDWORKS Pipe Route Overview
SOLIDWORKS Mold Tools - Shut Off Surfaces, Parting Surfaces, and Tooling Split
About Tashayla Openshaw
