Querying SOLIDWORKS PDM Database: Read-Only SQL User
Article by Francisco Guzman on Feb 28, 2016
This is part of a series of articles aimed towards providing the basics of creating queries for SOLIDWORKS PDM vault databases. Administrators will be able to collect data for their own purposes that are not attainable from SOLIDWORKS PDM out-of-the-box search features.
This article guides through the process of creating a read-only SQL user account in Microsoft SQL Server Management Studio (SSMS).
If your company has a Database Administrator, and you have been granted access to perform queries against your vault database, request your read-only user to your Database Administrator or IT. There are many ways to create a read-only user and they may have the best way for you and your company.
Follow this guide if you do not have a Database Administrator but still wish to use your granted access to query your PDM vault database.
Steps
  1. Log in to SSMS using an account with sufficient access to create the read-only user. Typically the built-in ‘sa’ account has sufficient permissions.
  2. Expand the plus sign next to the security folder.
  3. Right-click on logins and select “New Login…”
  4. When the “Login – New” window Appears, select on SQL Server Authentication, provide the name and password for the user.
    SQL server authentication
  5. On the left-hand side of the window select on User Mapping, Check the box for the database you want read-only access to, and check the boxes for the following:
    1. db_denydatawriter
    2. db_datareader
      querying solidworks pdm database read-only sql user
  6. Click OK, and you are all set!
More PDM Articles
SOLIDWORKS PDM Database: Query Planning
Change SQL from Full Recover to Simple Recovery Model
Automatic SQL Backup - SOLIDWORKS PDM Standard
About Francisco Guzman
View all posts by Francisco Guzman
