The Dynamic Design Analysis Method (DDAM) is a methodology developed by the U.S. Navy for testing shock loading from underwater explosions. SOLIDWORKS Simulation Premium can test your designs using this method.
In order to run an analysis using DDAM, the following four steps must be completed in the following order:
SOLIDWORKS Simulation calculates resonant frequencies and mass participations. Below are the modal results a 3’ x 4’ aluminum sheet mounted on the deck of a ship.
SOLIDWORKS Simulation Modal Results
Resonant Frequencies and Mass Participations
SOLIDWORKS Simulation produces results which should satisfy the requirements of DI-ENVR-81030 .
Some customization of the SOLIDWORKS Simulation results and exports will likely be needed to make sure the data is recognized, and the requirements are completely satisfied. SOLIDWORKS Simulation can export a printout of the input data ( SS_Sample.DAT ) in several formats to include details like node point locations.
Nodal forces and connector forces may be missing from these exports and may need to be exported manually from some plots in the SOLIDWORKS Simulation interface.
For users who are ok with generating their own shock loads and who prefer the intuitive SOLIDWORKS environment, SOLIDWORKS Simulation Premium can run your DDAM studies. This tool makes it easy to test design changes since studies can be automatically re-meshed and re-run after using SOLIDWORKS to change features and dimensions in your model.
Want to learn more about performing studies in SOLIDWORKS Simulation? Check out the related links below.
Understanding the Rattleback Mystery with SOLIDWORKS Motion
Piecewise Nonuniform Pressure in SOLIDWORKS Simulation
Introduction to Structural Analysis Using SOLIDWORKS Simulation Tools
SOLIDWORKS Simulation Frequency Analysis Comparison Between FEA & Real Life
About Shaun Bentley
