This article is a quick reference for SOLIDWORKS users and IT professionals. It shows how to optimize your SOLIDWORKS performance with Windows settings to make SOLIDWORKS run as fast as possible on any system. Extensive testing was performed by the editors at Desktop Engineering. Below are important summaries every SOLIDWORKS user should know.
The screenshots that follow show the changes you can make to SOLIDWORKS default settings (outlined in red boxes) to achieve the best performance.
Go to System Options and click on the General settings in red. Make sure that 'When rebuild error occurs' is set for Prompt.
Go to Options and click on the Drawings option for settings in 2014 and earlier. For 2015 the settings have been moved to the drawings/performance option as outlined in red above.
Go to Options and click on Display Style under the Drawings option and follow settings in red boxed outline.
Go to Options and click on the colors option and follow settings in red boxed outline.
Go to Options, click on display/selection option, and follow settings in red boxed outline.
Go to Options, click on the Performance option, and follow settings in red boxed outline.
Go to Options, click on the Assembles option, and follow settings in red boxed outline.
Go to Options, click on the External Reference option, and follow settings in red boxed outline.
Go to Options, click on Feature Manager Option, and follow settings in red boxed outline.
Go to Options, click on the View option, and follow settings in red boxed outline.
*Turn off common SOLIDWORKS Add-Ins that are not in use.
*Have virus detection exclude .slddrw .sldprt .sldasm on local machines and on servers if allowed. See how to exclude in your virus detection brands help!
Overall, Desktop Engineering researchers were able to decrease the baseline time of 5 hours, 1 minute, and 35 seconds down to just over 55 minutes. Here is a breakdown savings of the above settings:
Longtime SOLIDWORKS users should check their templates. In the past, SOLIDWORKS set a high level for its image quality on the default templates. Anyone who based their templates on those old defaults may still be carrying that legacy.
Note: Users may not know that image quality can be stored inside of a document template. The only way to be sure is to check each of your templates and modify them accordingly. Image quality can be changed at the Assembly or Drawing level and propagated down to all of the individual parts.
Be warned, using these settings will not make your models appear to your graphic cards best. Users can adjust settings found under the image quality sections for compromising best performance/best appearance trade-offs.
How to Set the Virtual Memory and Windows Performance Options
In Desktop Engineering the baseline state, the macro script took 5 hours, 1 minute, and 35 seconds to complete the common SOLIDWORKS operations. With the optimal configuration, the program took 55 minutes and 19 seconds to complete — a time savings of 82% over the baseline state. In other words, the optimal state configuration completed its engineering tasks 5.5 times faster than the baseline state.
Desktop Engineering has reviewed many ROI calculators to help estimate the value earned from workstations that make design engineers more productive. For powerful workstations that cost between $3,000 and $4,000, a 25% improvement in engineering productivity will typically result in an investment payback in six months.
Also, consider using SSD hard drives and as much and as fast as memory as possible for any given machine. For a more detailed “video” description on some of the above settings see this video.
