Loading Fortus Material Canisters for Stratasys 3D Printers
Article by GoEngineer on Sep 05, 2024
FDM (Fused Deposition Modeling) thermoplastic filaments form the backbone of Stratasys' original core technology. FDM materials range from general purpose, like ABS, to composite-filled Nylon, to chemical-resistant Antero. Something all FDM materials have in common though, is that they are susceptible to moisture. Any moisture that infiltrates the filament strand will create bubbles when the material is pushed through the extruder, from that moisture boiling away as it's heated. Bubbles can cause print quality issues as well as clogged tips and failed prints. In short, moist filament can stall production and cost companies thousands of dollars in wasted material and machine downtime.
Stratasys takes moisture mitigation extremely seriously, especially on their Fortus line of industrial FDM 3D printers. These machines employ heat and airflow to actively dry the entire filament path, from the canister all the way to the print head.
As important as it is to dry the filament path, it is crucial to maintain a dry environment in the material canister itself. Fortus canisters are specifically designed to stay dry, employing several tactics in that effort, with a design as intuitive as it is effective. Here are the simple steps required to unbox a canister and insert it into the printer.
  1. Start by opening the box. Remove the steel material canister from its sealed mylar pouch.
    Stratasys Fortus Material Canister
  2. The canister has an anti-rotation plug inserted during shipping to prevent cross-winding. Peel back the foil tape far enough to remove the plug, then reseal the opening. You can use the flat side of the plunger to flatten out the tape as best as possible. The rest of the operations are completed on the protruding canister snout.
    Anti-Rotation Plug Stratasys FDM Material Canister
    Re-Tape Your Fortus Material Canister
  3. On the snout is a removable filament cap and a thumbwheel door, which seal the filament path and thumb wheel respectively. Both components have thick gaskets and are designed to be opened and closed for the life of the canister to keep moisture from getting in during storage. Remove the filament cap to expose the filament lead, and place the cap underneath the filament drive wheel door for storage.
    How to Remove a Fortus Filament Cover
    Stratasys Fortus Filament Cover
  4. Open the filament drive wheel door and roll the rubber wheel down with your thumb to begin driving the filament out of the canister. Note: Never move the cartridge with the door open, you want to make sure the door is closed whenever moving a canister.
    How to Load Stratasys Fortus Material
    ROLL WHEEL DOWN
  5. Pull out about a foot of material to make sure the material comes out freely.
    Tips for Loading Fortus 3D Printing Material
  6. Push about 6 inches of material back into the canister. This will reduce the tension and will reduce the risk of the filament falling all the way back into the cartridge. Close the door so the filament is locked in place and then cut it flush.
    Reloading Material Canister 3D Printing Tutorial
    PUSH IN 6"
  7. Slide the canister into the desired material bay.
    3D Printing Material Bay
  8. Pull out the drive block handle and drop it into place to lock the cartridge.
    Lock 3D Printing Cartridge
    PULL OUT AND DROP DOWN
  9. Open the material drive wheel door and use your thumb to roll down the rubber wheel. This will push the filament up into the drive block sensor. Once the sensor is triggered the light above will start flashing green specifying that the material is ready to load.
    Fortus Filament Drive Block Sensor
  10. The inside of the door has a rectangle-shaped orange sponge. This sponge acts as a brake and keeps the filament locked in place while the door is closed. At this point, we want the material to come out freely so we need to peel off the brake pad. The sponge has double-sided tape so it is easy to store by sticking it underneath the filament cover.
    How to Lock a Fortus Filament in Place
  11. We can now close the door and load material from the machine main panel.
    Stratasys Fortus 3D Printer Main Panel
Pulling out a foot of material and pushing back 6 inches of material into the canister helped us reduce the risk of losing the filament inside the cartridge. Without doing this trick, you can load material, but the wheel will be more difficult to spin downwards and the filament will have a natural tendency to want to drop back into the cartridge. This trick helped us make a small task just a bit easier.
Editor's Note: This article was originally published in June 2016 and has been updated for accuracy and comprehensiveness.
More 3D Printing Tutorials
Stratasys Slicer Updates for FDM: GrabCAD Print & Insight
Stratasys Industrial 3D Printer Maintenance Tips: Fortus Edition
5 123 Series Maintenance Tips for New Users
Fortus Tip and Build Sheet Combinations: 3D Printing Tutorials
A Tip for Changing Tips: Fortus 3D Printer Edition
VIEW ALL 3D PRINTING TUTORIALS
