How to Remove the SOLIDWORKS Toolbox Flag
Article by Gary Ballentine on Sep 15, 2020
Want to create a custom part from a Toolbox item, but SOLIDWORKS is still showing the toolbox flag in the Feature Tree? That’s because it’s still linked to the Toolbox part! Here’s how to permanently break that link and dissociate it from the original file.
solidworks toolbox item
Save Your Part
Before making any changes to the part, we need to save it. This way, we have a distinct part file that we can divorce from the original part.
removing the toolbox flag in solidworks
Run the SOLIDWORKS Executable “sldsetdocprop.exe”
Browse to the <install directory>\toolbox\data utilities folder and locate the executable file “sldsetdocprop.exe”. A typical file path will look something like this: “C:\Program Files\SOLIDWORKS Corp 2020\SOLIDWORKS\Toolbox\data utilities.” When you find it, right-click on it and select “Run as administrator.”
running the solidworks executable
Change the Property State to “No”
Now we need to tell SOLIDWORKS that this is OUR part. In the dialog box that’s opened, set “Property state” to “No.” Now, select “Add Files…” and browse to the part file you created. This is the setting that breaks the link.
set document property screen
Update the Status
Now that we have the right file and setting selected, we need to click “Update Status” to make the changes permanent.
set document property update status
Verify That it Worked
You should be all set, but if you want to make sure it worked, just select the file in the same dialog box and click “Show Selected Property.”
show seelcted property
You’re All Set! The feature tree should now show a part icon as opposed to the toolbox icon.
feature tree show a part icon
solidworks 2021 rollout events
more SOLIDWORKS tips & tricks
SOLIDWORKS Pack and Go and Copy Tree Tool Comparison
Missing File Locations in SOLIDWORKS? Let's Find Them!
4 SOLIDWORKS Part Modeling Tools that are Time Savers
About Gary Ballentine
