Often a SOLIDWORKS user will have the wrong file location paths for an installation of SOLIDWORKS, which can cause the program to either fail or produce ineffective behavior. This article provides a clearly defined outline of the referenced paths that SOLIDWORKS requires to perform correctly.
Note: You may have to close SOLIDWORKS to save the options and file location(s)
Document Templates | C:\ProgramData\SOLIDWORKS \SOLIDWORKS version\templates |
C:\Program Files\SOLIDWORKS | |
Corp\SOLIDWORKS\lang\english\Tutorial | |
Bend Table Template | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
BOM Templates | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
Color Swatches | C:\Program Files\SOLIDWORKS |
Corp\SOLIDWORKS\lang\english\colorswatches | |
Costing Report Template Folder | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
Costing templates | C:\Program Files\SOLIDWORKS |
Corp\SOLIDWORKS\lang\english\Costing templates |
Custom Property Files | C:\ProgramData\SOLIDWORKS\SOLIDWORKS version\lang\english |
Design Library | C:\ProgramData\SOLIDWORKS\SOLIDWORKS version\Design Library |
Dimension/Annotation Favorites | C:\Users\user\Documents |
DimXpert Callout Format File | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
Hole Callout Format File | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
Hole Table Templates | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
Punch Table Templates | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
Revision Table Templates | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
Search Paths | C:\SOLIDWORKS Data\ |
Sheet Formats | C:\ProgramData\SOLIDWORKS\SOLIDWORKS version\lang\english\s heetformat |
Sheet Metal Bend Line Note File | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
Sheet Metal Bend Tables | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english\Sheetmetal Bend Tables |
Sheet Metal Gauge Table | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english\sheet metal gauge tables |
Sustainability Report Template Folder | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
Symbol Library Folder | C:\ProgramData\SOLIDWORKS\SOLIDWORKS version\lang\english |
Title Block Table Template | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
Weld Table Template | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
Weldment Cut List Templates | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english |
Weldment Profiles | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english\weldment profiles |
Weldment Property File | C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english\Weldments |
