Most software packages are designed to cover a wide range of situations, and Stratasys Insight software is no exception. This can be seen in the general settings for tool paths, infills, slice heights, and the purge/sacrificial towers. The default purge tower for a Stratasys F123 series 3D printer is depicted below next to the L Bracket. In this tutorial, learn how to create a custom purge tower using Stratasys Insight software.
F123 Series printers use a purge part on the tray instead of a purge bucket, like other Fortus machines, which reduces head movement per layer and print time.
Purging is needed when the printer switches from printing model material to support material in each layer. This process ensures seam quality is consistent for all parts on the tray. Purge towers will also often collect the ooze and bits of plastic from aging material. Lastly, purge towers improve the part quality for Nylon-based filaments on any machine.
Occasionally, the default purge tower doesn't do enough. Luckily, Insight has a few tools built in to help us out.
Below are steps to create what I call the Super Purge !
If you want to learn more about these commands, consider enrolling in our self-paced Insight training class.
Meet the F3300 3D Printer from Stratasys
GoEngineer 3D Printing Services: Stronger than Ever
Customize Insight Software Interface
Introducing GrabCAD Control for 3D Printer Management
About Jeremy Marvin
Jeremy Marvin is a Senior Digital Manufacturing Application Engineer at GoEngineer.
