Create Custom Materials in SOLIDWORKS
Article by GoEngineer on Jan 12, 2017
Although SOLIDWORKS has an extensive material library, users often need to create custom materials. The ability to add custom materials enables users to calculate an accurate mass or simulation of a part or assembly. The following steps demonstrate the processes to create a new material in SOLIDWORKS.
Step 1: How to change the material in a part or simulation
In a SOLIDWORKS part, materials can be changed by going to the design tree, right-clicking Material, and selecting Edit Material
In a simulation, materials can be changed without opening the individual part. Simply right-click on the part in the design tree and select Edit Material.
Creating Custom Materials in SOLIDWORKSApply/Edit Materials in SOLIDWORKS
Step 2: Create a new library
Once the Martial dialogue box is open, scroll to the bottom of the material tree. Right-click on custom material and select New Library, then create a New Category within the Library. This example uses a library called Custom Plastics and a category called Non-Linear Plastics. Click Apply
Create New Material Library in SOLIDWORKS
Step 3: Create a new material
New materials can be created by copying and pasting a similar material, or entering the material properties manually. Existing SOLIDWORKS materials cannot be edited. To copy a material, simply click on a material in the existing SOLIDWORKS Library, right-click and select Copy. Right, click in the new category and select Paste. Click Apply
Create a New Material in SOLIDWORKSUpdate Material in SOLIDWORKS
Step 4: Set the new material properties
Select the model type, and enter the values by double-clicking the value box. Click Apply
Set New Material Properties in SOLIDWORKS
Step 5: Apply the new Material to the part or simulation
Apply Custom Material in SOLIDWORKS
Congratulations! You have now successfully created a new material in SOLIDWORKS.
Expand Your SOLIDWORKS Skill Set
Quick Clicks in SOLIDWORKS
How to Install and Troubleshoot Fonts in SOLIDWORKS
4 Part Modeling Tools that are Time Savers
