A “Parallel Installation” of SOLIDWORKS is any time more than one version (i.e. 2011, 2012, 2013, 20XX, etc.) of SOLIDWORKS is installed and operating on a single system. This setup does not require additional licenses as both versions operate under the same serial number and the same license runs both installations. When working with multiple companies, each company may have their engineering department frozen at a particular version of SOLIDWORKS. It is always best to match their version of SOLIDWORKS to ensure design changes can freely flow back and forth between companies.
The reason a “Parallel Installation” is setup in this way is to prevent a messy file structure on a CAD computer. A messy file system can have several consequences:
Each of these items contributes to lost productive time due to causing:
Ultimately, two simple edits during the initial installation can alleviate many of the problems. It is recommended to use only the version of SOLIDWORKS and not include the service pack number as it is common to upgrade an existing installation between service packs rendering the installation directory an inaccurate description of the installation.
Each SOLIDWORKS installation on a single machine should go through the following process:
Provided by Jackie Yip
Q: Why would a user want to keep multiple versions on the same machine? Shouldn’t we always be on the latest release?
Many users work with vendors that are still on different version. Saving files in that older version of SOLIDWORKS files will work with the newer versions but not vice versa. Therefore, keeping different versions of the software allows customers to work with their vendors accordingly.
Q: How is my serial number affected? Does it take up an extra activation? Is there an extra cost for keeping multiple versions of SOLIDWORKS on the same machine?
Keeping two or more versions on the same machine will use the existing serial number that is currently on the machine and therefore, an extra activation is not taken up. We can theoretically have multiple versions opened up at the same time due to this. This applies to both a standalone and network license.
Q: Will we run into any issues with settings and other related products if we keep multiple versions of SOLIDWORKS?
Please refer to this link about coexistence rules: http://help.solidworks.com/2019/English/Installation/install_guide/c_product_coexistence_rules.htm
If we’re running a newer version on a network license, the SolidNetwork License Manager will need to be updated to match to most up-to-date version.
Q: Is there a way to copy our settings from different versions (ex. Toolbars, shortcuts, etc.) using the Settings Copy Wizard?
Currently, the Copy Settings Wizard will not carry settings over from different versions. However, if a newer version is installed after the older version, SOLIDWORKS will copy the settings to reflect the most recent earlier version installed on the same machine when the newer version is opened for the first time.
Q: If we longer need to keep the older versions, is it safe to uninstall?
Due to how multiple installs can share common files, we typically don’t recommend uninstalling the older versions first if a newer version is already installed. The safest way to get rid of the older versions is to either run a clean uninstall of all SOLIDWORKS versions or to uninstall the most current versions and then perform an upgrade if needed.
I hope you found this tutorial helpful. For more tips and tricks just like these, be sure to subscribe!
This article was originally published in January 2013 and has been updated.
About Ryan Dark
